Question about ASUS A7N8X-VM Motherboard
Computer powers off about 2 times during a session
My computer powers off sometimes when i open no particular programm. It coud be any programm. For example i tried opening itunes, outlook express. I tried plugging my monitor and my computer in another outlet but I am having the same problem. I tried scanning for viruses but the scan does not show any real threats. Can you help me solve this problem?
  • 1,601 Answers
Look for a heat problem first or RAM problem second.
For the heat problem, blow out the case, fans, processor heatsink and fan. for memory testing get memtest and run. If these dont work look at the power supply.
Posted on Jan 02, 2008
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Jun 26, 2016 | Zanussi Dishwashers
Why am I being asked to sign in to my Google toolbar account every day>?
Maybe you access your acc on another machine, that why is ask for.
So try this:
You may not want to sign out each time when using your own PC, but it is particularly important to sign out if you are accessing your account on a shared computer or public network. However, if you forget to log out, you can log out of all previous sessions the next time you are at a computer.
To do this, open your Gmail or Google Apps account and click on the Details link in the bottom right of your screen. This will open up a pop up window where you can see recent activity, whether your Gmail or Google Apps account is open in any other location, and choose to Sign out of all other sessions. Clicking that button will ensure all your previous Gmail and Google Apps sessions are logged out, leaving you logged in to the current computer only.
Mar 31, 2014 | Dell Inspiron 530 Desktop Computer
Hi my computer has had a google earth programme
Hi Yvonne, all u have to do is restore your computer to a previous session that worked and you icon will be shown on yo desktop.Hop this will help,thanx.
Jun 29, 2011 | HP Computers & Internet
How do I set the current time on the 12 cup programmable coffee maker. The hours unit only goes form 0, 1, 2 then skips to 12 thru 19 and back to 0.
I suggest programming it during those hours.
between midnight to 3 am or noon through 8pm.
sometimes it is easier to go with what works instead of asking for it to work perfectly.
Dec 28, 2009 | Black & Decker 12-Cup Programmable...
Router dell 2350 not detect by computer
open a explorer session go to tools/ internet options/connections/lan settings check off Automatically detect settings click ok, ok close explorer then open a new session and see if you get internet.
Oct 17, 2009 | Dell Wireless 2350 Router
When i try to open the mmc/sd card it does not opens it said the i/o device error
Sometime the card says the device error but there is another way to access or open that device. Some cause of the device are not properly remove during the last session use. To open that device you can go to my computer. When you are now in my computer their is a address bar the you can see the arrow left side of the address bar you need to click and look for the device you need to open. Now it will go directly to the device. Good luck
Hope it is helpful for you
Oct 04, 2009 | HP Pavilion a430n PC Desktop
I am having problem in starting up my system.once system has shutdown ,it fails to start immediately after pressing the start button.even after 2-3 hrs it does not start on pressing the start button.but...
Let me tell you that do not use UPS current on to the computer as the current in UPS is (AC) it would blow whole of the power supply or might effect to your Computer processor. As now you are suggested to get new power supply. hope fully this would work
Aug 30, 2009 | Computers & Internet
Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi ZWF1430W Front Load Washer
Program Freezes
There are several factors that can make your screen freze at an specific programme:
1)The program is not compatible with your operating sistem.
Solution: You can only reinstall your operating sistem OR another version of the operating sistem.
2)The programme is nit compatible with your computer and that is a serious problem. You can try to change your RAM Memory but I'm not sure if it works.
3)Some problems occured during the programme installation. Easy to fix: Reinstall the programme.
4)Maybe your computer doesn't have enough resources for that programme. You can add some extra RAM Memory. That may resolve your problems.
Dec 26, 2008 | Adobe Photoshop 7.0 for PC
ASUS A7N8X-VM Motherboard Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
