KitchenAid 300 Watts KSM90 Ultra Power Series Stand Mixer
Problem for KitchenAid 300 Watts KSM90 Ultra Power Series Stand Mixer
By gudjonbm on Oct 30, 2009
Problem for KitchenAid 300 Watts KSM90 Ultra Power Series Stand Mixer Motor will not operate
Best Solution
posted on Nov 06, 2009
Helpful)
lilhelper
Rank: Guru  KitchenAid Expert
Rating: 97%, 47 votes
This is common problem among kitchenaid mixers. If you are hearing no motor sound what so ever, The likely cause is the carbon brushes are worn or gone completely, and will need to replaced, they are located at the left and right sides of the unit and only fit ONE way. part number for both brushes is W10260958 and comes one in a package. These are a wearable part and when gone will not create an electrical field for the motor to run. If however these are visually OK, the next probable cause of this will be the motor control board, this can cause a great deal of electrical burning smell when it goes. part number for the board is W10119326. The board can be replaced but does require some know how of the unit.Hope this helps
Thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for KitchenAid 300 Watts KSM90
Questions and Unsolved Problems for KitchenAid 300 Watts KSM90
Do you recommend KitchenAid 300 Watts KSM90 Ultra Power Series Stand Mixer?
Answer
Answer
the speed selector switch will not stay "off'. does not catch. any movement of the mixer... (More)
Answer
when moving, the mixer was placed on its side for a period of time, causing oil to leak out into the... (More)
Answer
The kitchenaid ice cream maker drive assembly does not fit on to my mixer because of a metal disk... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For KitchenAid 300 Watts KSM90...:
Top Mixer Experts
Rank: Guru Guru
Solutions: 2519
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Mixer Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
