the pilot on my fridge runs for a couple minutes then a small cluncking noise from the fuse box and then the check light comes on it is a 1999 dometic rm2652
AC input power to fridge doesn't work. DC Power / Gas does work. Fuses are good on control board....
(More)
AC input power to fridge doesn't work. DC Power / Gas does work. Fuses are good on control board. and there doesn't seem to be any damage to the board. The Main Power ON switch works with DC but does not come on for AC.
refrigerator only runs on gas, when set to auto, it trips the GFI plug. I was told about a defrost...
(More)
refrigerator only runs on gas, when set to auto, it trips the GFI plug. I was told about a defrost ''board''. Can anyone help?
How do you regulate Dometic to stay at 36 degrees. Our Dometic gets down to 26 and 24 degrees, which...
(More)
How do you regulate Dometic to stay at 36 degrees. Our Dometic gets down to 26 and 24 degrees, which is too cold. There is a white slider on the right hand side of refrigerator for regulating the temperature plus a sensor that comes from inside of refrigerator to regulate. There are no other controls to regulate the temperature. Please advise.
the fc 140 will go down to -17 degrees f. when pluged into 120 volts but will only go to 27 degrees...
(More)
the fc 140 will go down to -17 degrees f. when pluged into 120 volts but will only go to 27 degrees f. when connected to propane. I have cleaned the gas jet, checked the flu and the flame looks good. I have another unit which is working fine, to compare the flame to and they both look the same.
