Question about Insignia NS-8PDVD
Unit will not charge
My power supply to the wall will not charge, the cord feels loose and the power light will not remain on therefore the unit will not charge. How can I remedy this problem
  • 579 Answers
Usually what happens is the power jack the cord plugs into is broken its solder joints. The manufacturers usually break the first rule of soldering which is to not rely on the soldering for mechanical strength.
If you feel up to totally dissassembling your unit to get at the bottom side of the circuit board, all you have to do is an easy resolder of the power jack.
Posted on Jan 02, 2008
Lights will not turn on
I experienced the same problem. One day the lights on the unit weren't on. The wall outlet that the dishwasher uses had power because the Garbage Disposal that also uses the same outlet had power. Turns out the power supply cord also tied to the water supply hose and had over the months (due to the constant slapping or dancing of the water hose whenever the electrically controlled water valve was opened or closed), had caused the female receptor prong inside the wall outlet to loose continuity with the male prong of the dishwasher power cord. It might have been a defective wall plug all along but the wall outlet worked for months before the problem arose. Anyway, after replacing the wall outlet the dishwasher again has lights and works fine.
Mar 06, 2015 | KitchenAid Dishwashers
My 4+ yr old hp g60-235dx won't power up anymore...
If the computer does not power up with either this would seem to be telling you that possibly the power cord is not working. Just because there is a light on the power supply unit does not mean the unit itself is working. Obviously the only other problem will be check the plug input as well to see if it is loose or feels wobbly is that is the case replace I would start with a new power supply unit go from there.
Jul 25, 2012 | HP G60-235DX Notebook
Our magellan keeps turning off. the plug seem loose. could it be the cord or is it the battery and can it be changed
Check your power cord. You may be losing power at the plug. When plugged in it may be losing contact with the recepticle. The power indicator light initially comes on but, breaks contact and therefore stops charging the unit. If this is the case you can sometimes plug into an adapter and get a tighter fit.
Apr 25, 2011 | Magellan Roadmate 1200 Car GPS Receiver
Orange light 3 flashing
Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green
Dec 29, 2010 | Microsoft Xbox 360 Console
My xbox has a three light red ring
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
    Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
My older xbox 360 has 3 segments of the red ring appearing. Can this be fixed? My son thought this could be fixed by microsoft at no cost to me. Is this true? If so, how can I accomplish this?
  2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
  3. Make sure that all three connections are firmly secured.
  4. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this: xboxconsolevertical.jpg
Dec 28, 2010 | Microsoft Xbox 360 Console
My xbox is giving me 3 red rings which should mean that there is a connection or hook up problem ive gotten it to work after this once but there were no connection problems then after not playing it for a...
  5. Check the light on the power supply. If this solution worked, your power supply light will be green....
Dec 23, 2010 | Microsoft Xbox 360 Console
I DO NOT HAVE THE POWER CHARGING CORDS... ONLY THEAIN PART OF THE LIGHT/INFLATOR . WHAT POWER SUPPLY CLORD IS USED?
On the side of the unit is a small black flap that covers two prongs that you can plug a standard 110-120 volt extension cord into which will charge the unit. There are 3 read lights and 1 green lights on the top that lets you know when it is fully charged. The 12 volt charging cord is basically a cord that has 2 cigarette lighter plugs. One plugs into the unit and the other plugs into a power port/cigarette lighter plug.
Jul 16, 2010 | Vector 1 Million Power Series Spotlight &...
I have a kscs25inss kitchenaid refrigerator. I opened the door and there was no power, the unit was not running (no compressor, no lights, no water). The circuit breaker did not trip, but I reset it...
Hi, Most likely the outlet has a loose wire or the cord for the refridgerator has a loose wire. Check the outlet on the wall see if it moves at all or has any loose wires in the back...if that looks ok replace the cord to the refridgerator. If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Sep 18, 2009 | Refrigerators
Insignia NS-8PDVD Logo
67 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
