I can not get my cd drive to open nor the motherboard to recogonize it--I just installed a new motherboard--please help
I can not get my cd drive to open--it has my motherboard cd in it and I need to open to put in my start up cd to re set the motherboard that I just installed--The light comes on and stays on and there is current going to the drive--
  • 1,601 Answers
Take a paper clip and straighten it out and put it in the tiny hole and push. It will open the cd drive.
Posted on Jan 02, 2008
  • Thomas Christopher
    Thomas Christopher Jan 03, 2008
    If this worked for you could you please rerate as FIXYA?
Mother board not recognised
If the CD is ment to your motherboard, it should recogonize it. If it dow not autorun, open the file and click setupexe.
Feb 07, 2012 | Intel D945GCCR Motherboard
My Mercury Motherboard CD is not working. I have just installed the new Hard Disk and trying to install the drivers, but I am not able to do so. Please help me with this asap. Regards, Dillip...
Download the drivers from here:
If the CD DRIVE is not working, replace it
IF the CD itself is not working, throw it away
Burn the drivers you downloaded to a CD for later use (when you have replaced the CD drive)
Jun 23, 2011 | Mercury P4VM800M7 Motherboard
I need help installing a cd drive in an Antec Sonata III 500 computer case. How do I do it?
Unplug the power from the computer. Open the case cover. Carefully remove the placeholder on the front of the case where you wish to install the CD drive. Make sure you have the proper ribbon cable for the type of drive you are installing and that you know where to plug it into the motherboard (consult your motherboard manual).
Use the screws provided to secure the drive to the chassis rails (make face of drive flush with front of case). Attach an available power supply connector to the new CD drive. Close the cover.
Dec 04, 2009 | Antec Sonata III 500 - mini tower - ATX ...
No video. The board does not recogonize the
try another monitor. try a PCI graphics card the on board video is likely bad.
Aug 03, 2009 | PC Chips M825G Motherboard
Pxe-e61 media test failure
This POST error refers to possible fault with the disk controller or the hard disk. Most likely you have a faulty hard disk.
Try reseating the hard drive first and if the problem remains then you need to test the hard drive. Do this by removing the hard drive and connect it to an USB hard drive adapter and connect the adapter to a working computer's USB port. If this computer see this as an external hard drive and you can open the various folders and files, then the hard drive is OK and the fault is the disk controller on the laptop's motherboard.
If the hard drive is not recogonized then it is faulty and you need to purchase a new hard drive, install Windows etc. to get the laptop functioning again.
Jul 09, 2009 | Toshiba Satellite 1805-S274 Notebook
USB drivers not supported in A8V-MX board usb not installing..saying windows not recogonizing device. mbd cd says will automaticaly install if sp1 & above is present my pc is sp3 .. kindly help
Enter the BIOS and change the setting of the USB speed to HIGH SPEED. The other setting is FULL SPEED. Whichever was enabled, do the opposite. Also go to this link:
where I found an update for USB drivers in the utilities section. viz. .check it out.....sodeep
Microsoft KB817900 USB fail to enter S3 patch file for Windows XP
May 02, 2009 | ASUS A8V-MX Motherboard
Dvd disk drive not showing in my computer
The chances are that the drivers for them got corrupted and you can install them fron your motherboard cd. To install them go to Control panel-> add new hardware-> search for new hardware-> if it shows up then its good else add them from the list. It will then install the drivers from your motherboard cd (the cd you got with your system or from the cd you got with your disk drive).
If this doesn't help then check for the connectors(going into disk drive from power supply and motherboard) by opening your pc.
Please rate the solution.
Feb 08, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
I tried to install my hp laserjet 3015 several times but I failed
  • It may take a little time for the CD to begin reading. Hit retry.
  • The CD may be damaged
  • The program may not load automatically
  • Go to the Start menu and then click on "Run". When the Run window appears, click on browse. Choose the D drive (or the one that reads your CD). Look for a file that ends in setup, execute, or install (these words my be abbreviated)
  • Double click on the file and it should be displayed next to "open" in the "Run" window.
  • Click okay and the program should begin to install.
Jan 28, 2009 | HP LaserJet 3015 All-In-One Printer
Installatin problem xp
do you still have the other hard disk? Is xp installed there?
Then you can use the old disk as master and the new disk as slave disk.
Don't you have another hard drive? Then you just need your xp cd and put it in your cd drive. start computer and installation will automatically start. Make sure BIOS is set to boot from cd
if you need more help, just reply
Apr 04, 2008 | Computers & Internet
New install of msi mainboard, no display on monitar or cd rom work
reinstall ur motherboard and cheak properly that ur mbo dont touch with earthing ( cheak ur power supply proper earthing )
Jan 05, 2008 | Intel Motherboard
Computers & Internet Logo
328 people viewed this question
David Payne
David Payne
