I switch the dryer on there is a buzzing noise coming from behind the time knob then 10 seconds later the filter care light comes on the dryers drum doesn't move during this and I have cleaned the filter etc still nothing
HI. the filter is fine. Anytime you can hear a buzzing, That is behind the timer module, this will indicate that there is a serious issue concerning the timer mechanism. This device is damaged. The actual timer motor is failing. This will not allow for proper advancement of the cycle selected, in this case. The entire timer control device will need to replaced asap. Once replaced, the unit will operate correctly.
tumble dryer door catch not working. ive unscrewed the catch and removed it but im not sure where...
(More)
tumble dryer door catch not working. ive unscrewed the catch and removed it but im not sure where the metal curve piece is supposed to sit ?
when switching on the dryer it does not spin just same sound as if the cycle has finished.i have...
(More)
when switching on the dryer it does not spin just same sound as if the cycle has finished.i have opened top of dryer and switched on and the on light goes on and off.wondered whether it was relay circuit whether it has burnt out.
my water full light comes on after a short period and stops machine leave for 30 mins or so and it...
(More)
MY WATER FULL LIGHT COMES ON AFTER A SHORT PERIOD AND STOPS MACHINE LEAVE FOR 30 MINS OR SO AND IT GOES AGAIN FOR ANOTHER SHORT TIME
