Weber Genesis E-310 Gas Grill
Problem for Weber Genesis E-310 Gas Grill
Gas not getting to stove to ingnite
By dhwright104 on Oct 30, 2009
I have two full fresh propane tanks. When i connect them and try to ignite via lighter. The gas sputters and never fully ingnites. Do I need a new gas line from the grill to the tank??
Best Solution
posted on Oct 30, 2009
Very Helpful)
bulldogchief
Rank: Guru
Rating: 94%, 163 votes
It sounds like you may be "vapor locking" the grill...after you are done cooking on the grill, how do you shut it off? Do you close the tank valve first then close the burner valves or do you turn off the burner valves then shut the gas off at the tank? If you turn the burners off before turning the gas off, you are creating a "vapor-lock" where air gets trapped in the line and you get the sputtering you are talking about.
Try this first, turn the gas on, then light the grill...once it is lit, turn off the gas and wait for the flame to fully extinguish then turn the burners off. Now try to light it again...if it is still sputtering, repeat the procedure above to purge the air out of the line.
If that procedure does not fix your issue after three tries, go get a new line and regulator and install then do that same procedure again. This should fix your issue once and for all.
If you experience any trouble with this, let me know here. Good Luck!
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Weber Genesis E-310 Gas Grill
Questions and Unsolved Problems for Weber Genesis E-310 Gas Grill
Do you recommend Weber Genesis E-310 Gas Grill?
Answer
Answer
I am moving from US to Italy. can I convert my US Weber genesis E310 for Italy propane tanks?
Answer
I have a Spirit Weber 310 and when I turned on the propane tank. The burners slight are on, or... (More)
Answer
My WEBER SPIRIT 310 PROPANE GRILL. I open the propane tank and open the first handle at 90 degress... (More)
Answer
How should I clean the inside and outside of my stainless steal grill?
Answer
When we light it only the left and right burner will work and then if you try and light the middle... (More)
Describe your Grills and Smokers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Grill and Smoker Experts
Top Range & Oven Repairmen
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Best Grills and Smokers
Recommended by Owners
See more>>
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
