Question about Gateway M305CRV Notebook
DVD Stutters My Gateway Laptop has stuttering issues with the DVD player. The CD works fine. Whenever I play a movie, the movie runs in a slowdown mode both with the audio and the video. It plays as if there isn't enough power to run it. It sounds a lot like an old cassette tape player when the battery ran down. I am obviously on AC power, so it isn't a battery problem.
  • mrrob12 Jan 02, 2008
    I appreciate your answer, however, I'm not sure how or why the jacks are pertinent?? The system is completely internal and if it were an electrical problem, why would the CD continue to work?
  • mrrob12 Jan 08, 2008
    PGJandover you should go work for Gateway!!! Awesome job!! The website you provided hit it right on the nose. I'm a computer idiot and fixed it!!! I had Gateway support both on-line and on the phone and they had NO CLUE!!!! Nice job and thank you!!!
Most likely, WinXP is forcing your Secondary IDE (master) to run in PIO mode rather than DMA mode. This could come about after playing a scratch DVD. WinXP makes a quasi-permanent change here that you cannot alter with Device Manager.
Here's the solution I found at http://winhlp.com/node/10
To Remedy, use regedit:
Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}
(note ..96A-E325... is UNIQUE)
Under this key, look for the entry "0000" or "0001" etc. that has the following properties:
DriverDesc = Secondary IDE Channel
MasterIdDataChecksum = ?some value?
Delete the MasterIdDataChecksum line from this entry, then reboot windows.
Verify using Device Manager that the secondary IDE channel is now "DMA mode".
Good luck.
Posted on Jan 06, 2008
    Problem Solver:
  • 5 Answers
CHK CABLES IN SIDE 2/3 TIMES REMOVE AN PLUG IT SPRAY SOME GOOD QUALITY ANTIOXIDENT IN JACK LET IT DDDDDDDRY COMPLETLY..ASSEMBLE IT ENJOYYYYY. BY
Posted on Jan 02, 2008
Dvd no sound windows media player
Simple Codec issue, Install and run VLC VideoLAN Official page for VLC media player the Open Source video framework
Once installed right click on the DVD in my computer and select play with..... and choose VLC
May 09, 2014 | Gateway 838GM (RB838GM) PC Desktop
Blu Ray Playback issues
The player may not support different video formats of your new files and I suggest you go look for a new one that plays most of the video formats like Macgo Mac Blu-ray Player, VLC, etc; you can also go CNET to search for a suitable one. Good luck.
Dec 02, 2013 | Samsung BDC5500 Player
Movie playback is really jittery?
Try using VLC media player to play your content.
May 03, 2013 | GoPro Digital Hero 3 Digital Camera
My gateway M-6846 notebook stutters when playing music. How can I fix this?
this can be caused by a number of things
are you playing music through your cd rom
If you are using your CD/DVD drive, use a cleaner.
The lens may be dusty and causing skips/stutters place a couple of drops onto the cd and run it
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now you might have a virus or malware
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer which can affect all of your computer
hope this helps
Aug 22, 2012 | Gateway M-6846 Notebook
My dell studio laptop (one month old) has problems playing dvds
It sounds like you have eliminated a media player problem.
Here are some more things you could try:
Disable your antivirus when playing the movie.
Have Dell replace CD/DVD drive. I got a bad drive in my new Latitude and they replaced it. It was a long phone call...be prepared.
It could be overheating. Make sure you have good air flow under the notebook. They make notebook coolers which you can find with a web search.
If this helps please vote for my solution.
Jan 19, 2010 | Dell Studio 15 Laptop
DVD plays well until it stutters midway thru and
If it only happens with one disc, try using a Disc Doctor/Skip Doctor on it. These instruments will repair scratches and depending on the disc, repair pinholes in the disc. Usually it's just polishing the surface of the disc. Some instruments totally resurface the disc by stripping off a thin layer of the disc to remove scratches and other damage. (Used game/music stores will do this).
Aug 29, 2009 | Panasonic DVD-RV31 DVD Player
My sound stutters on my Dell Inspion 6400 whenever I put a DVD in
You are very welcome. I am glad I could help. Apparently what happens is that the drive takes errors and XP downgrades the transfer mode. Once that happens you will have flaky problems, another problem you will see when this has occured is when you try to burn a CD or DVD. It might burn for a while and then just towards the end it will fail.
Thank you for letting me know it worked.
Apr 05, 2009 | Dell Inspiron 6400 Notebook
Wont play burnt dvds
Hello i have the same player and i had to do a Firmware Update to update my player so it won't cause this problem (also it could play the recent new blu ray movies). Go to www.sharp.net.au for Australia or www.sharp.net.nz for New Zealand. go to Support, Downloads, put in your Model number then it should have a list of updates you can use. If it says for USB then download it to your USB and then plug it into the back of your player. Go through your operation manual to how to do Software Update, then follow the instructions. If it says for cd/dvd then burn it onto the disk first.
I hope this helps. I can play burnt dvd's on mine with no worries.
Sharon
Feb 24, 2009 | Sharp AQUOS Blu-ray Disc Player
My dvd player stutters when I play a movie
Not enough RAM or CPU too slow for movies.
Feb 18, 2009 | Sony VAIO FXA63 Notebook
Will not play blu-ray disc's
Is the Firmware going thru completly What version do you have for the UP5000?
Oct 01, 2008 | Samsung BD-P1200 Blu-Ray Disc Player
Gateway M305CRV Notebook Logo
105 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
