Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
Refridgerator Not Cooling
We had trouble a few months back with the fridge overfreezing. We unplugged the unit and plugged it back in and that seemed to solve its problem for a while. Now it seems that the freezer is fine...a little frost is appearing but staying cold. But the refrigerator sensor seems to not be working properly. We have it set to 7 and its barely cold. We have thrown out contents due to this issue at this point. We unplugged the unit again...a few times in the last couple of days and you can hear the unit making the differing noise that seems like it may be generating some cold (possibly) and then it shuts off after about 10 seconds after we plugged it back in...and again the fridge doesn't seem to be cooler at all. It seems to be a sensor not reading correctly since the freezer works but that is just a guess. Any ideas?
  • 5 more comments
  • ron6333 Feb 28, 2008
    Hello i am having the same problem with my Amana refridgerator. My freezer is icing but my the fridge is not cooling. I unplug it and i thaws out and then the refridge cools again for about a week and then the problem percist again. The freezer has ice build up. Can you help me? I have a Amana27 unit.
  • sparky_b Apr 08, 2008
    For the second time in 8 months the refrigerator in our Amana has stopped cooling. Freezer seems to be working fine. Tired of throwing away expensive spoiled foods. Last repairman left part to replace on condensor unit, blug it in and problem not resolved. Refrigerator is less than 5 years old.
  • Anonymous Apr 28, 2008
    I have a ABB2225DEW with the same problem. I turned off the unit, unplugged the unit and proceeded to remove the freezer drawer and all components including the rear panel to see the cooling coils. The coils are frosted over. A hair dryer will melt the ice. This fixes the problem but only for a few weeks. From what I can tell, it seems to be a broken Defrost Limit Thermostat OR Defrost Heater. Seeing a picture of the later online, I do not remember actually seeing on in my unit???!!! I plan to take it apart again tonight to see if Amana forgot to install one! So far, that is the best I can come up with for a possible cause to this problem. These parts are easy to get to once the freezer and back panel are removed. Parts are also inexpensive.
  • bettercadd Apr 28, 2008
    I also have the same problem. Everything was functioning normally this morning. Tried the fix of unplugging the machine but have yet to experience success. Perhaps a service technician can fix it?
  • bobefisch May 16, 2008
    I Am having the same problem with no cooling in the Refrig and freezer works fine. Unit is an ABB2224DEQ about 2.5 years old. What a pain the ****. Any other suggestions???
    bobefisch
  • Anonymous Jul 16, 2008
    Fridge and freezer is not cooling. Tried to turn up cooling but this did not work. Please help.
  • renneke Sep 08, 2008
    Freezer gets super cold, NO air going up to the refrigerator. Can not find the defrost timer switch?? What the heck!!!!!!!!!1
The coil was frozen on my unit as well. Guinco tech Ron announced that this was a bad system board. Seems to be resolving as of this writing.
Posted on Apr 29, 2008
2 Suggested Answers
  • 6 Answers
SOURCE: Refridgerator Not Cooling
If top is compleatly warm it is probley the fan motor, lot of failures on them. Replacement one will be a different looking motor. Verify motor is not turning, located in the back of the freezer in the top middle, behind small grill. Will see fan blade pointed up, should run whenever compressor is on.
Posted on Aug 07, 2008
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Ffa47x fridge not cooling freezer overfreezing
there is a little air passage that allows the cold air form the freezer to cool the refrigerator is blocked or jammed closed check that first then you can get back to me
Dec 30, 2011 | Hotpoint Refrigerators
Is it possible to remove refridgerator, and clean under it? Bad smell under fridge. Help!!!!!
yes, in the back of the unit unplug the fridge and open the back panel with a few screwsand you should be able to reach underneath
Sep 07, 2011 | Refrigerators
Fridge not cooling
unplug unit and let sit overnight to defrost,
Oct 29, 2009 | Refrigerators
Our refridgerator is not cooling well.
These units only have coils on the freezer side and just blow cold air to the other side through small ducts. These ducts have a tendency to ice up and block the airflow. Do a manual defrost for about two (2) hours and then plug it back in. Hope this helps. Good luck.
Jun 05, 2009 | Admiral Refrigerators
Refridgerator stops cooling
Check the compressor relay near the compressor on the back bottom of the fridge. Check voltage it should read about 115, up above that there is a computer sensor, check that also has a fuse on it. One of the two is bad, they are cheap part and you can find them on LG.com
Feb 09, 2009 | LG 22.4 Cu. Ft. Bottom-Mount Refrigerator...
GE Refridgerator
I suggest that you check your defrost heater in the freezer. If this is the problem, then if you empty out the freezer section you will see a solid sheet of ice on the back panel. If the ice is there, then you may need to replace your defrost heater, we had this same problem just a few days ago. Once the heater was replaced, the fridge started cooling about an hour or so.
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Aug 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
363 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
