Solution #5
posted on Aug 09, 2005
Reynolds - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
I understand your confusion; we've all been there and there is something
more
to learn every day ;)
You were already close answering my question by trying Virtual Dub for
captures,
so I'll use that program as an example (you may want to try avi_io as it
offers
far fewer choices, but will still offer all you need to capture well &
robust).
For "normal" analogue capture cards it is generally possible to make a host
of choices for the input format
1. video
a. input source (e.g. composite, s-video, tv-tuner, DV-channel, etc.)
b. image resolution (e.g. 720x480, 352x240, etc.)
c. colorspace or encoding format (e.g. RGB, YUV, UYVY, MJPEG, DV, etc.)
d. frame speed (e.g. 15fps, 30fps, etc.)
e. recompression format (DivX, Intel Indeo, HuffYUV, etc.)
2. audio
a. mono/stereo
b. sample rate (e.g. 22500Hz, 44100Hz, etc.)
c. coding format (16 bit PCM, 8 bit u-law, 4-bit ADPCM, XXXkbps MP3, etc.)
So, my real question is:
Is it possible to select
For video
1a. (source) composite or SVHS
1b. (resolution) 720x480 (= max size I presume)
1c. (colorspace) RGB or RGBA (2nd choice would be YUV2 or UVYV)
1d. (framespeed) 30 frames/second (possibly 29.97 for NTSC)
1e. (recompression) uncompressed, or HuffYUV
and audio
2a. stereo
2b. (sample rate) 44100 or 48000
2c. (encoding) 16 bit PCM
Best possible capture would be SVHS @ 720x480x30fps in RGB format
uncompressed,
effecitively letting you capture the full image without *any* loss.
Could you give it another try, I'm really curious whether it is possible.
Thanks,
Erik.
