Question about IBM SureMark Printer TF6 Thermal Label
IBM SureMark 4610 USB
The printer prints the first receipt OK, then the next ones start coming out all misconfigutared. I have upgraded my FW to "Microcode EC Level is 47" and the same happens. If i restart the application im working with it happens the same, first OK second and so on BAD.
  • masherito Jan 02, 2008
    oh, another thing. When i say bad print i mean that between every character is a white space, even between white spaces.
  • bra_branko Apr 04, 2009
    I have a lot problem with this device. I can get Code page 1250 or 852. I dont know what is this device ????
You may need a new thermal head
Posted on Dec 12, 2008
You may need a new thermal head but i doubt so considering you get one good print out. I assume the good one is in great order. It could be a bad harness or requires you to update to format 3E
Posted on Nov 10, 2011
Stopped printing
reinstall your program for printer.if it dont work.
printer is bad.let me know.ok
Jul 21, 2009 | IBM SureMark Printer TF6 Thermal Label
Printing only one side
Most likely the small 'roller' on the LHS of the paper feed shaft is missing. This roller engages the metal 'yoke' on the LHS when the printer lid closes and provides a suitable pressure for the paper to contact the thermal head. They break into 2 pieces sometimes and fall away from the shaft. Solution: remove circlip and replace the roller if you can get one. I have them made.
Mar 26, 2009 | IBM SureMark Printer TF6 Thermal Label
Suremark 4610 on Sure POS system/ Laptop T23
We specialize in these products.
Capital Computer Group
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
Wethernb@capcom-ncr.com
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Jan 14, 2009 | IBM 4610 TG4 Thermal Label Printer
Printers Spew out 18" of journal tape every morning x 8 registers
Talk to the software suppliers on your Tills, they may have an idea.
Jun 17, 2017 | IBM SureMark Printer TF6 Thermal Label
Cannot get printer to print
very possible but you may need to disable the firewall if you have one then disable the antivirus . then try to reinstall software for the printer and follow directions closely. biigg53566
Dec 05, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM 4610 suremark receipt printer
Hello all,
had the same problem and my solution was to install the latest driver available at the IBM service/driver website. Then unistall it with another IBM driver cleaning tool, then repeat both processes a couple of times, until the printer responded. There is some bug on these latest drivers an older Windows versions, so only after some installations and repairs on the first install, windows gets it right. VERY STRANGE but it worked in 2 machines, both IBM terminal and 4610-tf6 IBM printer.
By the way; RS232 ibm cable...I believe its a null modem 9 pin...not a regular serial cable.
Dip pin config: my printers have 4 so; 1ON 2ON 3OFF 4OFF which means
1 size of paper you are using 80mm
2 if you use an IBM software or other:other
3 if xon/off or DTR/DSR:hardware
4 com speed: 9600baud or 19200baud, 9600
That's what I igured out. If you need any more info: mail
fit.frederico@gmail.com
FredP
Sep 28, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM 4610 TG4
Jacsmar,
The 4610 has several common routines. One of these common routines is CR.BUFFER.GUILOTINE This routine buffers the guillotine cuts written to the receipt station.  I believe you need to be sure that this routine is inserted in the printing program in order for the guilllotine mechanism to cut.
The routine should have the following defination:
SUB CR.BUFFER.GUILLOTINE PUBLIC  The other routine is:
DO.GUILLOTINE.CUT
Also simply listen to hear if the knife mechanism is trying to activate after printing a receipt.
Hope this helps,
G. Kiely
Sep 10, 2007 | IBM 4610 TG4 Thermal Label Printer
IBM SureMark Printer TF6 Thermal Label Logo
713 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
