Question about Microsoft Xbox 360 Console
No picture On several occasions when I switch on my 360 there is a problem with my picture. Its almost like when the horizontal hold is not set, but the screen is black as well with some purple faint diagonal lines and a few white ones scattered about. after playing around with the scart inputs and switching them around a bit I have managed to get it working again and so I assumed it was a problem with the scart input on the tv, even tho the freeview plugged into the scart socket the xbox was in still works. Today while playing Assassins Creed the game locked, said the disc was unreadable and booted out to the dashboard and then now have the black/ purple screen. Any ideas?
  • 85 Answers
This is almost identical to what happened to my system just before it gave me the red rings. I had to return my system. There is general hardware failure. The last lvl in assassins creed kept dropping me thought the map then i would get a checkerboard of purple and black squares all over my screen.
If you have a warranty i would return it to the store you bought it from and get a new one if not contact MS and see if they will cover it under there warranty. Since its a GPU failure i would think they would fix it for free but i cannot say for sure. They did extend there warranty on overheating which sounds like what has happend to yours to three years.
Posted on Jan 02, 2008
How do u reset your xbox format to pop up on your tv?
If you're using the XBox 360 component/compositve AV cable, try the switch at the base of the cable to switch from HD to SD or vise versa. If that doesn't work, try MS's official reset instructions:
To reset your display settings, follow these steps:
  1. Make sure there's no disc in the disc tray.
  2. Turn off the console.
  3. Turn on the console.
  4. Note If you're using an Xbox 360 Wireless Controller, make sure only one wireless controller is connected to the console, and then turn off and restart the console by using the Guide button on that controller.
  5. As the console starts, press and hold Y while pulling the right trigger on the controller. The display settings are reset to the default settings, and then the console automatically restarts.
    Xbox 360 E or Xbox 360 S console: To reset display setting on these console models, you can also just turn off the console and then hold the power button on the front of the console down for about 10 seconds. (The lights will flash several times.)
Oct 20, 2014 | Microsoft Xbox 360 Console
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
I need an instruction manual for a Canon sure shot a1 panorama date camera
Ordinarily the panorama feature is utilized like this: you choose a panorama subject, and move your camera on a straight horizontal line with keeping your shutter down, and trying to capture the whole scenes into the lens. You can also stitch several common photos into one panorama picture(in vertical, horizontal, tile, 360 degree, 3d) with some programs like ArcSoft Panorama Maker.
Oct 09, 2011 | Canon Sure Shot A1 Panorama Date 35mm...
I bought my 360 about 8 months ago and lately I have to turn the power on and off at least twice to get a picture or audio, and every once in a while the red light comes on. The console has severely...
one make sure your system is not not sitting at an odd angle, like leaning up against something. also check all your cables and connections to make sure they are tight. the 360 is designed to either lay horizontally or vertically but not at angle either 90degrees vertical or horizontal because any other way the system will not be stable and can damage your games. also you may want to try a diffent HDMI cable if thats what your using. it may be causing your issues as well
Jan 02, 2010 | Microsoft Xbox 360 Console
Xbox 360 has sound but no picture
you may have already checked this but is the switch on your video cable set to the right output type? There is HD and TV so you may have it set to the wrong one. Hope it's that simple...
Dec 02, 2008 | Microsoft Xbox 360 Console
Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Aug 07, 2008 | Panasonic CT-32G6 32" TV
Vivitar 8400 camera- horizontal lines on photos
in what mode do you take the pictures?
have you tried to reset it ?
Apr 26, 2008 | Vivitar ViviCam 8400 Digital Camera
Half a picture
Dont use the set and call a service tech,you might have loose conections in the horizontal circuit,if you keep using it for this problem it might become worst.
Aug 29, 2006 | Sony KV-36XBR450 36" TV
Approximately 10 years old
Check the cable type settings it may be a switch on the back of the set or by the antenna input or at the bottom back cover . If no switch then if theres an on screen menu it should be somewhere there. if theres no on screen then theres gotta be a switch. this switch changes the AFC on cable systems from irc ,mirc or normal try all three settings one at a time while changing channels thats where this works . Good Luck
Jun 05, 2006 | Philips Magnavox 27MS343S 27" TV
Microsoft Xbox 360 Console Logo
113 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
