Question about Nintendo Wii Console
Connecting to internet
Cant connect to internet i have a wired conection have bought lan adaptor using straight to modem then tried through router and im still getting error 50100
  • 3 more comments
  • johnrl Jan 02, 2008
    cant connect to internet i have a wired conection have bought lan adaptor using straight to modem then tried through router and im still getting error 50100 i have a separate line for my modem
    i have connected wii o adaptor the to ethernet then to back of modem stil getting errr code 50100
  • johnrl Jan 04, 2008
    im using windows xp
  • johnrl Jan 05, 2008
    i cant wii connect to internet i have a wired conection ihave bought lan adaptor and ethenernet cable using straight to modem im using windows xp
  • tiggeriswild Mar 09, 2009
    i want internet on the wii..
    i bought the LAN adapter as i want a wired connection, my computer has broadband with a modem,,
    what set up procedure do i do...? wats the ip address and the proxy code ect mean when trying to put in the sittins on the wii as i would really like the internet on my wii..?
    Scholar:
  • 131 Answers
Remove the router, connect the phone wire to the modem and the lan to the system, now configure the modem as per the ISP details. This should solve the Problem. the modem itself acts as a router, when you have two routers your default gateway in the lan prorepties should be configured with the ip address of the router which is attached to the phone line. More over the ip add of the routers might be the same as the default is 192.168.1.1.
Because of this you might be getting the error message.
Posted on Jan 02, 2008
  • M Karthikeyan
    M Karthikeyan Jan 03, 2008
    If you are using OS windows, then go to the control panel>>open network connections>> under "This connection uses the following items:" select Internet Protocol(TCP/IP) and click properties. In the Internet protocol (TCP/IP) Properties under general tab select the radio button "Use the following DNS server addresses." and enter the IP address of the router in the Preferred DNS server: click ok. You can also enter the Modem IP and try. Post Back with your status pls.
  • M Karthikeyan
    M Karthikeyan Jan 05, 2008
    You should configure your modem as per instructions from your ISP. get your ISP people to configure the modem.
  • 34 Answers
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Mar 06, 2009
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: connecting to internet
http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Posted on Jan 07, 2008
Wireless conection
To enable or setup the wireless on a modem router you usually have to connect the computer to the router with a lan cable first, go in to the routers settings, most routers use the web browser to access the settings but read the manual for the correct procedure. Then you put in your account details supplied by your internet service provider.
Enable wireless and apply security settings like a wep key, wpa, or wpa2 passkey. Restart the router, remove the lan cable and you're done.
When any wireless device tries to connect it will need the wep key, wpa, or wpa2 passkey to be entered to allow access.
Feb 19, 2012 | Computers & Internet
Hi I am using reliance broadband. They have
Easy, if your modem is connected to your computer right now and internet is working all you need to do is connect your LAN line to your belkin router. the connection should say input, or Internet. after that you will need another LAN wire (These look like telephone cables but the jack plug is larger and will only fit a lan connection on your router or computer) Connect the second wire to the line 1 or outout 1 from your router, to your pc in the slot where the other cable was connected. your internet signal should work.... on your mobil find any available network and log in to your belkin router.
that should do it.... if you haven't set up your internet connection, do that first by installing the drivers for the modem provided by your provider and then complete the process above.
Oct 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Not able to configure and connect to internet using router
Try 192.168.0.0 which would be the default address to access your modem. This should allow you to go into the modem and adjust changes. I know on the bottom of my router there is an administrator default password that can e used to access the mainframe of the modem. Check out these features in there. I would start first by connecting via LAN again and then try to conntect to it via a WAN but again see if you can access the modem using the 192.168.0.0.
May 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Conection to the internet through land line
Land line? oh i see... wired connection. It looks like there is a problem connecting with the LAN adaptor.
The Error code has to do with some problem connecting via wired connection.
Try pluging it off and on again while the system is off
Try connecting it with a different LAN cable
Try fine tune some settings on the Wii system options
Try connecting with an other LAN adaptor.
Make sure that the LAN adaptor you are using is made from Nintendo.
If still not working just call the local Nintendo Customer Service and report the problem.
Jun 25, 2008 | Nintendo Wii Console
Jan 05, 2008 | Nintendo Wii Console
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Modem conection
In order to troubleshoot this problem, I need the following information:
Are you using a router?
What OS do you have?
Does your modem have a steady "online" light?
What IP address is coming up in ipconfig?
Oct 03, 2007 | Computers & Internet
Nintendo Wii Console Logo
117 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
