FixYa.com
Tags:
Panasonic DP-150A Grayscale Copier
Xerox Copier Machine - Error U4
posted by siku on Jan 02, 2008
Dear
i have a Xerox Copier Machine model No. 5825, it is not working showing the error code U4. kindly assist me how to solve this problem thanks
M. Sikander Saleem
sikander786@yahoo.com
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 17, 2008
Not Rated (0)
hpzrcheep
Rank:Wiz Wiz
Rating: 81%, 14 votes
before replacing the fuse test it with an ohms meter
you can reset u4 codes from the control panel-let me know if you want further assistance.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 02, 2008
Not Rated (0)
tryit
Rank:Guru Guru
Rating: 87%, 521 votes
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Can you Help with these Copiers problems?
Copiers
Konica 7030 copier/printer -...
A service code of f 32-4 comes... Answer This...
Copiers
minolta
minolta ep 1030 copier paper... Answer This...
Copiers
cf323
same probelem Answer This...
Copiers
Nuvera 100 CP
I have a Xerox Nuvera 100 that... Answer This...
Copiers
toner drum chip reset for xerox...
Sir, I am Ekambaram from India.... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
