Question about RCA P46921 46" Rear Projection Television
Picture problems I have a 48 in rca rear projection tv. it is 3 yrs old. Lately the picture gets bigger then the screen, then it goes back to normal and then it shrinks small and there are grey edges along the sides then it all goes back to normal and it keeps doing this while watching. It gets worse on the really high channels such as 500 plus and the pay per view stations. I called dish network but they said it was a tv problem. I went into the tv remote menu and checked the tv format. But still it doesnt work properly ,, what can I do?
  • 4,402 Answers
If it's Narrow on both sides, height and width vary with scenes
try replacing C4407, CR4403
Posted on Jan 02, 2008
I'm seeing double pictures/letters on my 48inch JVC (I'ART) projection big screen tv. It's like the yellow wants to separate from the rest of the colors. What could be causing this problem? The tv is about...
one of the convergence ICs is probably defective, you will need a soldering iron to replace this . there are 2 of them,they start with a part no STK392-XXX
Jun 07, 2009 | JVC AV-48WP30 48" Rear Projection...
Red shadow
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Mar 22, 2009 | Mitsubishi WS48511 48" Rear Projection...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
my tv is 12 yrs old it started with the color starting to fade and then it started cracklin real bad and now theres no pic but there is sound
Dec 29, 2007 | RCA P60921 60" Rear Projection Television
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
Picture fluctuates
your location area may be theres a big machines interfering your AC line. as you've noticed it runs normal intermittently. i suggest to use a AC condenser or a AVR for this might solved your problem. good luck.
Aug 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Projects picture bigger than screen..
This must be a duplicate, and since I'm not sure which one you'll be checking back with: Go into the menu and select picture settings and then advanced picture settings. I'm not sure on that model that you can manually change the aspect ratio from zoom to 16:9 or 4:3 ect... But select Auto Format and the TV will pre-select the correct format for viewing..... Any questions just let me know. Bill
Jun 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P46921 46" Rear Projection Television Logo
81 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
