Question about Asko 24 in. 1895 Built-in Dishwasher
Asko dishwasher the dishwasher won't shut off
  • 126 Answers
Most likely the main switch is bad.
Posted on Jan 24, 2008
6ya staff
SOURCE:
My Asko dishwasher won’t start and beeps every few minutes
here is a usable resource.https://youtu.be/GGTueTi33dg
i have checked out this video and i feel it may be Very helpful to you.
Mar 31, 2018 | Asko Dishwashers
I have an asko d3251 dishwasher that won't stop running. The device in the drain that spins won't stop. I had to shut the power off to the unit.
Our unit had leaking connection on outlet side of fill solenoid valve. Any leak will cause water to accumulate in base pan. there is a float switch in base pan as a safety mechanism when water is in pan it causes a styrofoam float to rise and make contact with switch. This tells machine there is a leak creates error code to run pump continuously until water is removed from base. Disconnet electric from unit first. you must pull dishwasher out to get at back panel. Remove lower back panel to get access to mechanicals of unit. Once you remove panel you should see water in pan. If you see water that is most likely same issue we had. soak up excess water or tilt unit to drain water out of pan. once water is gone unit should start normally. If you look underneath while unit starts up - don't touch anything while unit is connected to electricity! You should notice where water is coming from. Our unit leaked at hose connection from outlet side of solenoid fill valve. connector is a plastic cam-lock fitting with a flow sensor integrated into it. there is an o-ring between the two parts. it comes apart with a very small amount of counter-clockwise motion. perhaps only five or ten degrees of indexing and it falls right off. it is a very flimsy connection for the main water line. the o-ring on our unit Was slightly deformed and not seated correctly. could have been from original installers 4 years earlier! Asko needs to re-design this part. I replaced o-ring and unit is working again however I do not trust that this fitting will hold up over time. Very poor design in my opinion. Other design flaw I noticed while looking at mechanicals is circulating pump isolation mount is not in correct location for pump motor. rubber mount is stressed to the point of almost tearing off! No way for me to correct this since location of mount does not match position of motor. We will not replace this unit with another ASKO when it goes.
Jan 19, 2013 | Asko D3251HDSS Stainless Steel Built-in...
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
Asko D1796 control panel will not reset....it is showing 5 on it
shut power off at breaker, look under washer there is a pan, if any water is in that pan, there is your problem, remove the water with a towel, plug washer back in
Oct 31, 2010 | Asko D1796FI Built-in Dishwasher
Asko 1350 fill problem.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve if found to be defective.
Now, if the valve is ok, replace the control.
In most cases, this will be a control fault.
Jun 21, 2009 | Asko 1385 Dishwasher
ASKO dishwasher
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Mar 27, 2008 | Asko D1776 Stainless Steel Built-in...
Asko 1895
water in base remove dishwasher and tilt to side and it will restart,but you may have a leak,also check the inlet valve may not be closing fully.hope this helps.
Mar 06, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Waterpump won't shut off
if you mean drain pump it may be due to a leak there is a flood switch under the unit
Jan 20, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Dishwashers Logo
148 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
