Question about Microsoft LifeCam VX-3000 Web Camera
Loud static Hi, I'm having problems with the audio.....  I hear very loud static on playback and not much else.  If I shout into the mic, or clap, I can sometimes hear that but not when i'm talking normally.  I've played around with the settings- with no success!    help!
  • micahsw Nov 11, 2008
    I also get a huge amount of static, but it isn't my windows live settings, I'm testing the hardware in my audio properties and getting the same problems. I have reinstalled the drivers a hundred times and reinstalled the full software for lifecam and cannot figure out why all I get is static. For a long time I had the camera configured as my microphone and yet one day I started to have this problem, I have no idea what changed to cause this.
    President:
  • 4,402 Answers
Verify that your microphone is configured correctly loadTOCNode(2, 'resolution'); 1. In Windows Live Messenger, if you cannot see the menu, click Show Menu. 2. On the Tools menu, click Audio and Video Setup. 3. Click Next two times. On the Microphone page, verify that the correct microphone is selected on the Select the microphone you would like to use drop-down list. Speak in a typical tone of voice, and then verify that the voice meter moves up and down correctly. 4. Click Next, and then click Finish.Loud static - uparrow.gifBack to the top
Verify that your contact's speakers are working correctly loadTOCNode(2, 'resolution'); To do this, have your contact follow these steps: 1. In Windows Live Messenger, if you cannot see the menu, click Show Menu. 2. On the Tools menu, click Audio and Video Setup. 3. Click Next. On the Speakers page, verify that the correct sound system is selected on the Select the speakers or headset you would like to use drop-down list. 4. Click Play Sound, and then verify that you hear the sounds correctly. 5. Click Stop Sound. 6. Click Next two times, and then click Finish.
Posted on Jan 09, 2008
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
Static noise
Try connecting an external mic while recording. If it works fine, there may be a probem with your mic
Dec 28, 2013 | Samsung Series 7 Slate Pc Tablet Windows 7...
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
My N95 has a loud beeping sound when making or recieving calls so loud you cant hear the other person talk.
It appears that you have microphone feedback between Mic. and speaker.Mic sensitivity to high in usual cases or audio output to high or both. Only solution is to have it repaired by an expert.
Mar 15, 2011 | Nokia N95 Cellular Phone
Hi i am using the audio technica at2035 condensor mic and the m audio mobile pre 2nd gen. audio interface. yesterday the mic was working fine with no problems but today for some reason i have to really...
This mic has a 10db pad or attenuator switch near the bottom of the barrel... make sure you haven't accidentally engaged it.
If that's not.... it try changing the lead. Also the power supply on your preamp could be failing.
These are a few cheap things to try before spending money for fixing.
Nov 29, 2010 | Audio Technica AT2035 Professional...
Camera records loud background noise.
Ensure your webcam mic is set as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
If the problem is due to feedback try using a set of headphones
Jun 06, 2010 | Logitech Webcam
I can hear my voice in my headsets..its very loud..if I blow into the mic..its like an actual live mic
all headsets feature what I think is called side tone. you need to hear a bit of yourself when speaking on a microphone as a bit of communication reassurance. When thew microphone level is up way too loud , that's more than side tone, it's annoyance that's when you get the problem that you've listed. I've seen it on telephone headsets and Mobile Phones but i'm sure it would happen on gaming headsets too...
Good Luck
Jan 17, 2010 | Logitech Audio Players & Recorders
Microsoft VX-6000 audio problem - static noise coming from speakers
My webcam VX6000 picture is fine, but when i try to talk to anyone or do voice playback there is a loud echo and distortion both for me and the person i am trying to talk to. I have tried everything in support. I am running windows xp.
Dec 27, 2007 | Microsoft LifeCam VX-6000 Webcam
Computer problem
The iPhone is set up funky.
One of the ports on the bottom is the speaker, and the other is the mic.
It's not dual speaker like it looks. So it's coming from the right place. It's just not that loud.
That's one problem the iPhone has. Playback audio isn't loud enough.
Nov 05, 2007 | Apple iPhone Smartphone
Microsoft LifeCam VX-3000 Web Camera Logo
141 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
