Question about Sylvania 6427TE 27" TV
Remote The remote will not work the tv.
  • dlld441 Jan 08, 2008
    Hey,I used the wrong mod.# it is srt4127f,my local tv shop said that this not a good mod number,asked if i got the tv at wal-mart.was told ot is a throw away.I will open the remote and look for loose solder joints.the tv was my dads and he opened the set and cleaned the remote eye,it worked for a short time after that then quit again.
  • 149 Answers
Hi there, you can clean the inside of the remote and look for some lose solder or some corouded parts. remote can be repaired. ty
Posted on Jan 02, 2008
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
Remote does not work
Infrared sensor inside the TV is damaged. Replace it.
May 17, 2013 | Televison & Video
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
The remote control sensor on the TV has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 09, 2012 | Televison & Video
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Cant get the remote to work for menu options just started setting it up already programed to my direct tv remote now nothing is working or either remote t.v or direct tv remote
To diagnose a remote control problem follow these steps.
1) unplug the TV power cord, count to five and plug it back in. (reboot)
2) try to power on with ORIGINAL MANUFACTURER remote.
if that works- your TV and original remote are fine.
if that does not work:
4) try to power on with buttons on the TV itself- if it works- check your remote batteries and try remote again.
Direct TV and Dish Network remotes will ONLY operate SIMPLE function of your TV such as power, volume, input.
They will NOT access your TV menu.
Apr 12, 2011 | Televison & Video
Panasonic 42 inch HD Plasma TV (2 years old) remote sensor
take your tv and remote to a technician to check on your emitting diode and a photo senser, both are working but not very sensitive. the components are not gone but about to go. if you remove a senser from tv it can not receive, so that senser is sensing some thing, also check an amplifier just after a senser plse do that.
Nov 16, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Remote randomly works. 27" Symphonic TV... but remote works on other Symphonics in the house
I would get a new remote control first. Just because it is the same brand doesn't mean the same reote codes are used.
Apr 05, 2007 | Symphonic ST419E TV
Sylvania 6427TE 27" TV Logo
27 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
