Question about LG enV VX9900 Cellular Phone
Orange LG EnV
Phone not charging; difficulty with a number of chargers. Replaced charger was okay, then charger had to be propped up in a certain position to charge, now no charge at all. Could it be the charger port, and if so can this be replaced without sending it back to LG.
    Sergeant:
    Champion:
  • 310 Answers
If you look at the charger port you will see a metal sleeve around the inside. Itneeds to be bent a little in so it will make the soket tighter. then the socket needs to be cleand out with a small brush. I use a old dry tooth brush
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 02, 2008
  • PDCates Aug 23, 2013
    I have a LG VX5400 doing the same thing and I had wondered if the port could be bent back into place and cleaned. It would take a small thin-edged tool to do the job. What do you use?
How do you fix the charging port on a lg 9900 phone?
You could have a charging port issue, you may need to install a new one into the phone or order a backup battery plus a battery charger, interchange them as needed.
Jul 15, 2014 | LG Pcmicrostore Brand Lg Env Vx 9900...
LGNV 2 won't charge. Whenever I plug it in it stays black
Have you use another charger to charge the phone to comfirm that it it is not charger problem? If you have and yet did not charge.
It means the the charging port of your phone is bad and will need to be replaced in other for your phone to charge.
Change the charging port as advice and you will see that your phone will charge.
Take care.
Apr 26, 2010 | LG enV VX9900 Cellular Phone
LG enV2 Battery not chairging
It might be your charger or your charger port.
First check the charger by using another charger to test if it will charge.
If not charging that means your charging port is faulty needs to be changed.
Jan 21, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
How do you dismantle the end of the charger?
Absolutely not. You must use the LG charger, or you might get an improper amount of current into the phone and toast it.
Jan 04, 2009 | LG enV VX9900 Cellular Phone
Ive put my phone on the charge, but it isnt charging, whats the problem? my env cell phone isnt charging when i put it in the charger
Your port could be messed up or it could be the charger. Take it in to verizon and they will look at it for free.
Dec 15, 2008 | LG enV VX9900 Cellular Phone
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Broken charger port
i have the same problem with my enV my friend stripped the wires to my charger at the part where you plug it into the phone so now to charge my phone i tape the red wire to the positive on the battery and the black wire to the negitive there will be a shiny metal goldish color thing (there like 4 lil gold bars) on your battery that looks like this --> (negative) | | | | (positive) | - | | | + | tape the wires on the outside were the symbols are - and + and try not to let it toch the middle bars on the battery or it wont work and dont cover the little bars up with tape put the battery back in the phone making sure the wires dont move to much and it should charge sometimes you got tape the battery onto the phone to make sure it doesnt pop out but its what i do and it saves you money on having to go buy a whole new one or if you know someone with the same phone give them your battery to charge it :)
Apr 18, 2008 | LG enV VX9900 Cellular Phone
Env help plz
The reason the phone won't charge is because the internal power port pins are broken off of their solder joints to the main board inside the phone. Wiggling it helps at first because the pins can still touch their connection points but after a short time that will cease to help. Google "cell phone repair". It usually cost around $50 to get it fixed with a new power port installed. Turn-around is usually 2-3 days.
Mar 05, 2008 | LG enV VX9900 Cellular Phone
Charging
me and my dad have shared one lg charger for about a year and i havent had any problems, i think the only design problem with them is that the end of the charger, along with the cover for the charger in slot, are very very fragile. If you get a new charger just be really careful with it.
Dec 01, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
193 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
