Question about Estro Barista Athena
Starbucks Athena I dont have the manual and have no idea how to use this. The water heats and the steam vent for frothing works fine but the bottom 2 buttons for either one or two shots doesnt light up and it wont pull a shot. I got thtis from a friend used and they dont remember how to use it either so I am stuck. Can you give me any ideas? I let it heat up until the ready light went off. I can feel heat through the top of the machine but it just doesnt draw a shot. Any help would be greatly appreciated. I am thinking about taking it up to Starbucks to see if they can get it to work.
  • Anonymous Jan 04, 2008
    Same problem. Tried tightening, loosening hoses and tinkering with stuff (as much as I can, it's mostly electronics inside), with no result.
I have had this machine for four years now, and it is FAB!!! it does have an extra step to it- after you put in coffee and add water to the reservoir, you DO need to prime the pump. So here's what you have to do:
-Fill the reservoir with MORE water then you think you will need, fill the coffee filter with the standard amount of finely ground bean.
-Turn the machine to "on," making sure the "steam" switch and valve (knob) are off.
-Wait till the green "ready" light comes on, then put an empty cup under the steam wand and turn the valve on (the steam switch is still in the off position). Hot water will come out of the steam wand, allow it to flow until the "ready" light blinks off. Discard this.
-close the steam valve, stopping the flow of water.
-turn the "steam" switch into the on position, wait for ready light to come on again.
-put your milk container under the steam wand and froth to your heart's content (this machine makes GREAT frothed milk and you should use a large enough milk container to allow for that! *smile*)
-when you have finished with the frothing, close the valve and flick the "steam" switch back into the off position. You are now ready to make your espresso.
-push either of the two buttons, ie one or two cups, and the espresso will start to flow. There is a way to set the length of time for each of the two buttons, but I have had mine set perfectly for so long i don't know how to do it any more. Sorry!
This has been the best machine I've ever used, and has lasted me for years. I heartily recommend it!
Posted on Dec 17, 2008
In response to megsk8r, I've read in most coffee forums that you should prime every time you've let the machine sit for a day, no matter what you're doing with the machine. I.e., if you want to make a straight espresso and you haven't used the machine since yesterday morning, go ahead and prime the pump again. It only takes about 20 seconds maximum.
Posted on Sep 24, 2009
Hi musicgrrl11, Your response is very helpful! Anyone - please help!! - I had one question regarding her response - do you only need to prime the pump if you are steaming milk? Or do you need to prime it to make espresso shots too? I just got a Starbucks Athena from my in-laws that they were getting rid of, but no manual and I've never made espresso before. :)
Posted on Aug 10, 2009
Where did you get this espresso maker?
Posted on Dec 23, 2008
The Athena needs to be primed if it has been unplugged. To do this, make sure cold water is in the tank, turn the machine on and make sure the lever for steam is off. Place a cup under the steam valve, open the steam valve all the way and wait until water starts to stream out. Make sure to do this before the water heats up or you'll get steam.
Posted on Jan 19, 2008
Excellent - I have been trying everything. Priming it solved the problem and I am enjoying an Irish Creme Latte.
Thanks
Billyd
Posted on Jul 21, 2008
My steamer wand has an awful odor everytime I try to steam something! I have cleaned it (even soaked in baking soda!) and the problem won't stop. Anyone else have this problem?
This is a common problem for the commercial espresso machines, Due to lack of cleaning of the steam wand after they finish frothing milk.
The milk flows back to the boiler and the water gets contaminated with milk.
Does the steam smells like rotten milk? If the answer is yes, you have contaminated water and or lines.
If not may be there is a lot of IRON in the water.
Run a descale cycle.
After you are done frothing milk, wipe the steam wand with a wet towel and open the steam valve for 2 seconds, close it and that's it.
Jan 15, 2011 | Saeco Starbucks Sirena Espresso Machine
I have a starbucks barista athena that has a vapor lock. How do I fix this?
It's easy to break the vaporlock on an Athena.
  1. Power the machine off and let it cool (20-30 minutes is plenty)
  2. Place a mug under the steam wand and open the steam valve all the way. If there's residual pressure, let it release the pressure before proceeding
  3. Power on the machine and wait for a steady stream of water from the steam wand.
  4. Close the steam valve and you should be good to go!
Jan 14, 2011 | Estro Barista Athena
Water Leaks from the head gasket while heating up to use steam
This is a result of the water temperature in the boiler increasing, thereby expelling water that may remain in the lines out of their respective exit points. A solution may be to place a container under the group head to catch the water, or opening the steam valve partially to allow the water to exit through the steam wand (again placing a vessel/cup/pitcher there to catch the water). This is a problem that even higher end (dual-boiler) models have, due to the necessary purging of water that accumulates in the steam wand during down-time.
Don't look at it as a problem, but simply as a quirk that single-boiler machines have. If you are still irked by the issue, consider buying an inexpensive manual frother (Bodum makes these) to froth and heat your milk (in the microwave after frothing) separately. An added plus is that you can do this while you make your espresso, so if you make primarily milk-based drinks (latte, capps etc.) you'll save on time.
Dec 21, 2009 | Saeco Starbucks Sirena Espresso Machine
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
No steam when valve opened, spits out water in the beginning of frothing
There is a small teflon piece on the inside of the steam tube, you will have to disassemble the frother to get to it. Remove this piece. Reassemble and the wand should work fine.
May 08, 2009 | Gaggia Syncrony Compact Coffee...
Barista Zia Espresso Machine
file:///Users/Julie/Downloads/Barista_Final_011305.pdf
I had the same problem. The Barista Zia is the same as the Barista Athena on the inside, the only diffrence between the two is the plastic shell on the Zia, and the steaming wand is on the opposite side. This is the instruction manuel for the barista athena, so its basically the same. Thanks! good luck!
Nov 10, 2008 | Starbucks Coffee Makers & Espresso...
Estro Barista Athena Logo
1,660 people viewed this question
Top Estro Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you an Estro Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
