Question about Philips 32PW9308 32" TV
Philips 32PW9308 I have had my Philips Philips 32PW9308 for about 4 years and this morning the screen started changing colours and then settled down. I have now turned it back on and the screen is purple/pink in colour with horizontal lines. I can hear the sound, switch it over and even hear SKY when switched on but that is it. I have checked the leads and arial/dish and they seem OK. Another TV in the house works on the same TV arial so I presume it is the 32PW9308. Would it be the tube and is it worth repairing? I hope you can help me. Regards, Roger204
  • replican May 15, 2008
    My picture keeps changing from having a purple tint, to having a green one. Then it goes normal for a minute or 2 then goes purple again. The tv is 5 years old. Is it worth repairing.
  • lorry12 Aug 21, 2008
    same problem here.
    switching on it is ok.
    after a few secs it turns green screen
    switching on and off again gives picture ok.
    but problem happens every time I switch on.
    Lorry
  • 236 Answers
SOURCE: Horizontal lines slowly moving down
Sounds like you have a power supply filtering problem. Perhaps a filter capacitor is going bad. If your set has a switching power supply oscillations from it are getting into the video. You need to have a tech to check it out for you. You should get an estimate first before having it repaired. Stargazer
Posted on Mar 17, 2007
techman
  • 3130 Answers
SOURCE: Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Posted on Mar 27, 2007
  • 45 Answers
SOURCE: POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Posted on Nov 04, 2007
tvtek
  • 1284 Answers
SOURCE: CVI connection
On a Philips TV the only way I know to switch to any of the inputs is by scanning using channel up or down. This model is capabable of 480P input only at the CVI/Component input. This is not a HD television. It is only a EDTV (enhanced definition) if you try and input anything iver 480P IE: 720p or 1080i, the double image and/or lines is what you will get.
Posted on May 28, 2008
  • 8457 Answers
SOURCE: Rolling horizontal (colored) lines instead of picture; audio OK
This problems it pretty easy to fix.Just require take the tv apart.Resolders all the holes in the video board that connected to a long CRT tube neck.Should cost $50 -$75 more than that u are being cheated.
Posted on Dec 05, 2009
About phillips lcd tv
Display panel fault. Contact the authorized service centre for Philips. http://electronicshelponline.blogspot.com/
Nov 10, 2015 | Philips Televison & Video
Vx 570 auto settlementIf I manually settle my VeriFone credit card terminal in the morning, why doesn't it auto settle at the scheduled time that night?
the terminal is set internally to settle each day on it's own. you can have this turned off if you don't like the feature.
if you select the 0 key or press enter if 0 does not take you to configuration menu. enter your default password or 1 alpha alpha ( key is above the 2)66831 enter, then select the purple more key until you see merchant id.
select merchant id. then press next until you see auto settle time, press select when you see auto settle time. remove the time using backspace key, select exit and save changes red x to main screen. the auto settle should be removed now. but if you do a download you will lose this information so it is best to contact your processor to have your file updated.
May 19, 2014 | VeriFone Retail Supplies
Coulor fluctuation
Most likely the main board which processes all information including audio and video and chroma or color.
Dec 04, 2012 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
I have a 4.3 engine wont start in morning unless i pour gas in throtle body wont give a shot of gas when i turn on key but will start all day after first start in morning
without knowing the year, make,model,and mileage it sounds like you have a partially blocked fuel filter. the problem occurs after the vehicle sits for long periods of time such as overnight. the trash in the filter has time to settle and block the fuel line so the engine doesn't get the fuel it needs to start. by pouring gas into the engine you are allowing the engine to start and pressurize the fuel system and force the blockage out of the way enough to allow fuel to the engine, as long as you start it up every so often the the trash in the filter cant settle enough to restrict fuel flow. this will be a very good place to start looking for a fuel flow issue.
Apr 03, 2011 | Chevrolet 1500 Cars & Trucks
Clonk/know from engine when first driving off in 1st gear
Have the transmission checked, this could be a torque converter issue. It settles down after it starts and fills with fluid again.
Sep 09, 2009 | Toyota Corolla Cars & Trucks
Calapsed picture frame
This can only be a bad soldered on the video module, its better to check for any bad soldered and for any fault on the resistor on the video output module.
Hope this initial info / idea helps.
Please Accept my solution if I solved the issue.
Regards,
micro
Mar 27, 2009 | Televison & Video
Plasma Problem
It could be the Logic board or/and one of the Logic Scan board failure. Parts availability depends on maker and may cost any where between $250 - $500. Labour depends on shop. Hope that'll help you. Good luck.
Jan 26, 2008 | Televison & Video
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Sony Digital TV screen colour problems
My sony projection tv seems to be out of focus on all four side.
Aug 02, 2007 | Sanyo HT32744 32" TV
Mar 27, 2007 | Philips 28PW6506 28" TV
Philips 32PW9308 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
