FixYa.com
Tags:
Umax AstraPix 550 Digital Camera
Problem drivers for UMAX astrapix 550 and XP
By Green1 - usenet poster
does someone knows where i can find drivers for the UMAX astrapix 550 camera
the ones from the CD do not work
thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 09, 2005
FixYa! (100)
kioner
kioner - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Try their web site umax.com
They have some software available for download, but others require a CD
purchase...cheap at about $15.  I bought the CD when I was setting up a new PC
with Win XP, and it runs fine.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
The drivers work perfectly in Win-XP for this camera. I got one
yesterday. The manual doesn;t actually explain it, but I guessed cos
I'm clever like that!
1. Install the dirvers on the cd
2. plug camera into usb port and turn dial one notch. (once light goes
green you can turn to off position as camera is NOW powered by USB NOT
battery)
3. the camera will be recognised and drivers installed
4. unplug camera
5. Switch dial to pos 5 (software download) and select the 'other
setting' (select with u/down then press enter button)
6. replug in and Other drivers will be loaded
Use WDM setting for cam, use Mass storage setting for use as usb hard
drive.
I can assure you 100% it works. I have moved stuff to/fro it as a hard
drive + used it as a webcam in net meeting.
I am doing some testing and will post when done as there is JACK-SHit
info about this camera. Initial conclusion is its 'almost' amazing. It
does 4 things fairly averagely, photo, video, mp3, webcam (+ has a tv
output from where you can view photos/videos)
Initial findings :-
1) mp3 playback time on 4 x 1800 NimH AA's = approx 7 hours
2) Video mode = MPJEG 320x240 @ 15fps (approx 1800 kb/s)
+ Audio = PCM 176kb/s mono @ 11025hz
=> approx 17 mins video on my 256k compact flash
Video Quality is a bit lower than VHS I'd say but perfectly useable
when watched on a telly.
3) MP3 playback is very quiet and  fairly bass light. I'd guess it is
about half or lower than normal line input level. You can plug in any
headphones you want, I need to find some louder ones (anyone know any
good in-ear loud phones WITH inline volume control)
4) Weight with batteries = 300g
5) Picture quality - I dunno as I've not got much to compare it to.
Looks as good as when I've scanned in photos on a scanner. As someone
else said colors do look a bit washed out, but I'm just a happy
snappa. It has a lot of features that may improve on this such as
shutter speed / brightness ( 5 settings) etc, have to experiment to be
able to answer that.
It could have been awesome IF (in importance order ) :-
1) Volume of mp3 playback increased. + had a lock feature so playback
isn't stopped when dial accidentaly turned which happens far too
easily (a bit of sellotape is required). If it would allow a playlist
(just plays trax in order but you can stop and move to a diff track
and it will carry on from there) + ff/rw in track. The low volume
though really ruins this feature.
2) record using divx + mp3 (using pcm for audio = yuk) and up frame
rate to 20-25 fps then it'd be comparable to an analog video cam
3) It was a little bit smaller (it is about size of a small compact
film camera), but digi-cams these days are tiny, make it 1/2 the size
and deffo winner...
4) mp3 files are stores with long filename on compact flash BUT camera
only shows 1st 8 chars (old do
Can you Help with these Digital Cameras problems?
Digital Cameras
how do you transfer photos
how do you transfer photos from... Answer This...
Digital Cameras
trying to set up my
trying to set up my webcam to... Answer This...
Digital Cameras
Canon A75: LDC Screen displays
Canon A75: LDC Screen displays... Answer This...
Digital Cameras
I NEED THE DISC THAT
i need the disc that is... Answer This...
Digital Cameras
I have a Samsung digmax
I have a Samsung digmax 430,... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
