Minolta EP4000/5000 CS/PRO Copier
Problem for Minolta EP4000/5000 CS/PRO Copier
The copier is showing a paper jam on the left hand
By yolanda_hand on Oct 30, 2009
The copier is showing a paper jam on the left hand side. There is no visible paper, can you help?
Solution #1
posted on Nov 08, 2009
Not Rated)
copydoki
Rank: Wiz  Minolta Office Equipment  Expert
Rating: 81%, 123 votes
Check the exit sensor,clean the fuser parts and the transport rubbers,change the oil supply roller,and check the exit lever functions.
Was this helpful?
Yes
No
Solution #2
posted on Nov 07, 2009
Not Rated)
oliviosharpo
Rank: Master  Office Equipment  Expert
Rating: 88%, 4 votes
There are a number of possibilities, there might be a piece of paper blocking one of the jam sensors or the sensor involved is defective. But experience wise, the first is most likely. As you said, the indicator is on the left, presuming you mean the panel indication's left, check the output section which is the fuser unit. Most jams occur on this section.
Was this helpful?
Yes
No
Popular Solutions for Minolta EP4000/5000 CS/PRO
Questions and Unsolved Problems for Minolta EP4000/5000 CS/PRO
Do you recommend Minolta EP4000/5000 CS/PRO Copier?
Answer
Answer
how to install sharp AR-5316 to windows vista business
Answer
I need someone to show me how to make my Officejet 6500 709 series printer/fax, print for me.... (More)
Answer
the ricoh ft3320 i dont have repair book the coyer machine. i taking put paper in copy machine feed... (More)
Answer
dark copies, copier pc-6re needs cleaning, no manual
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Minolta EP4000/5000 CS/PRO...:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
