Sharp Projector Lamp for XG-P10X
Possible lamp problem for sharp pg-m10s
posted by tjk545 on Jan 02, 2008
physically the lamp looks new, it lights fine for around 15 seconds, the fans sound good but then the lamp goes out and the lamp/temp light turns red.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 02, 2008
Not Rated (0)
sedonix
Rank:Guru Guru
Rating: 86%, 497 votes
It is bad. They don't always explode when they fail.
Projection makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on possible lamp problem for sharp pg-m10s:
I don't want to Accept this solution
Can you Help with these Multimedia Projector Replacement Lamps problems?
LAMP/COVER Light on and the stand of the projector is not...
I have a HL-85086 that shuts off, seems to be a thermal...
Dear Sir, I want to control my panasonic projector...
I want know the E-mail Address & Tel No of local...
Powerlite S5 Series/77C Power off after 3minutes
Loading problems.
Repair Service
Find Multimedia Pro. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
