Question about Panasonic PT-LB20U Multimedia Projector
Distorted picture. The image projected is badly distorted (unrecogonizable picture) which occured after the bulb was changed. Fixable?
  • 442 Answers
Is the menu text clear on the screen, when it's focused correctly. Or is that also distorted.
If the menu text is OK then the picture signal is dodgy. could be due to a bad earth lead on the video cable.
Is it distorted on all signal inputs
Posted on Feb 28, 2011
SOURCE:
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
Multimedia projection tv distorted picture
IF IT'S A 3 TUBE PROJECTION TV, THEN THE COVERANGE IC'S CHIPS BAD
Jun 26, 2014 | Televison & Video
I have just turned my camera on and it is showing a very distorted picture. The pictures I took previously show fine but any new display or photo are very badly distorted.
This kind of problem occurs when ccd imager chip got bad in camera. Let me know model number of your Sony camera to provide you more info to solve its issue.
Thanks.
Dec 04, 2010 | Sony Cameras
Tv on my projection is distorted... 53' projection kp53h74
If distorted picture looks like 3 pictures or as 3-D image then tv got problem in convergence out circuit.
Please replace convergence out ICs in tv to get it fixed.
Mar 26, 2010 | Televison & Video
JVC-AV48WPT74 picture colors are distorted, looks like 3-D image
The convergence ICs and feed resistors need to be replaced. You can get the repair kit for your specific model at the following link. The convergence repair kit contains the replacement parts and the step by step repair proceedure on CD. Very easy repair. Just look under the JVC repair kit category
http://www.tvrepairworld.com/
Jul 12, 2009 | JVC AV-48WP74 48" Rear Projection...
When tv is turned on the picture is distorted.thought at first that one of the bulbs was bad.took the screen off and all bulbs are lit.the red bulb looks distorted.has the bulbs got to go out to be...
Can you explain distorted in more detail?
Does the screen look 3D?
Can you adjust the convergence for both the blue and red colors - up - down - left - right?
If not the convergence chips and resistors are shot and should be repalced.
If however the screen is shrinking and expanding that is a different problem.  You can get a repair kit from www.TvRepairKits.com for this model.
Dec 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence out power supply faulty for 46gw945 picture is distorted
You can get parts for your model by going to the following link and leaving them an email stating the model of your set and indicate which board you are needing. Heres the link
http://servicemanuals.vstore.ca/
May 05, 2008 | GE 46GW945 46" Rear Projection Television
Panasonic PT-LB20U Multimedia Projector Logo
284 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
