Question about Samsung DLP HL-P5663W 56" TV
T.V. turns off unexpectedly
I have had this T.V. for about two years now and have had it shut off on its own for about 4 months now. I thought that the lamp maybe overheating but it is so random (shuts off after 5 min. or 5 hours) that it couldn't be it. Also, it may take up to 10 times of turning it back on before it will stay on. When it finally does, it might go a day or two before turning its self off again. Please have an answer for me.
  • kristif Jan 03, 2008
    my samsung dlp 56" does not turn on the picture just the audio. it just keeps going to try to turn on and does not. i unplug it for a day then finally it started up. it has done this now in the last 4 months maybe 6 times. this time is has not turned back on even unplugging it.
  • sachinp Jan 17, 2008
    This happens more frequently to me when I am using HD content. When I turn on my PS3, instead of displaying the picture, some white and different colored boxes appear.
  • 796 Answers
There may be some problem in the power device section on the main board.......the power ic`s will not be functioning well due to heating
Posted on Jan 02, 2008
6ya staff
SOURCE:
I have a Mitsubishi WD52631 that seems to have intermittent problems turning on
Ballasts were sometimes problems with this set, but I also ran into problems with lamp thermal sensor. It's a small rectangular device sort of cream color and about 1/8th X 3/16th X 3/4 inch in size with lead coming out of one end. Also check safety interlock switch, which is actuated by lamp access cover being properly closed.
Jan 01, 2014 | Mitsubishi WD-52525 52" Rear Projection...
Projector Won't Turn On
HI,
Sounds like it may be overheating, have you cleaned the air filter. If the unit gets too hot, the projector will shut its self down.
Goodluck,
Please don't forget to rate the solution
Apr 13, 2008 | Sanyo PLC-XT11 Multimedia Projector
Optoma MovieTime: The Lamp that Won't stay on
its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light bulb.you can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
Aug 22, 2007 | Optoma MovieTime DV10 Multimedia Projector
Infocus IN72 - blinking RED light
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Mar 03, 2010 | InFocus IN72 Multimedia Projector
I have a sony kf50xbr800. This TV was purchased new in 2001. After 5 1/2 years the lamp had to get replace. TV been working good till now. While watching tv it will go to stand by mode, after about 2-min's...
The thought is that it needs to be either cleaned out. Dust build up in it's air intake filter or you probably need another new lamp. Usually when these set's shut themselves down is because they are overheating or they can't maintain the voltage to keep the lamp lit.
Blessings,
A/V Media Tech Guy
Nov 25, 2009 | Televison & Video
I left my infocus x3 on ovrnight wnet down this morning it was shut down when i start it up fans and everything work normal but the bulb doesn't on and it is a fairly new bulb it have had the x3 for about...
it's not recomended to run constant for a day or longer. it may have overheated the lamp. especially if you've never cleaned it out before. take canned air and blow out any dust. but first remove the lamp and see if there is dust blocking the side vent. if there is a lot, the lamp overheated and prematurely blew.
Oct 30, 2009 | InFocus X1 Multimedia Projector
TV on/off
How long is your TV on before it turns off? Check the fans and make sure they are all working. The TV may be shutting off due to overheating if a fan quit working.
If you think the lamp is still good maybe try replacing the lamp ballast.
Jan 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Our 2 year old 52" HDTV (Mitzubishi)
hi there.im not familiar with your actual set,but i assume it uses a metal hallide lamp,which,on average do around 2000 hours of use.lamp life is crucial to the cooling system,usually a fan.its paramount that this is working,and that the air intake filters are clean.the thermostat only ever fails due to the lamp overheating.which means the cooling system.most likely the filters,externally removable.regards,steve
Nov 05, 2008 | Mitsubishi Televison & Video
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Feb 13, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
107 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
