Home | Breville | ESP8XL Espresso Machine | The frother on my caf...
Breville ESP8XL Espresso Machine
Problem for Breville ESP8XL Espresso Machine
The frother on my cafe roma has stopped working.
By horsecash220 on Oct 30, 2009
the frother on my cafe roma has stopped working. I removed the wand but where the steam comes out is stopped up. how do i fix this
Solution #1
posted on Nov 08, 2009
Not Rated)
wire12me
Rank: Guru
Rating: 86%, 16 votes
The "frother" is probably blocked. Remove it and see if you can blow through it. If not, you can try cleaning it with a paper clip. If that won't work, place the metal frother tube in a pot of water with a bit of ammonia or vinegar in it. Heat the water to boiling, then let it simmer awhile. After it cools, try using the paper clip again. You should clean the steamer attachment after each use:
2. Remove the froth enhancer and rinse under warm tap water. 3. Wipe the steam wand with a damp cloth. 4. Briefly set the Selector Control to the ‘STEAM’ position to clear any remaining milk from the steam wand.
Was this helpful?
Yes
No
Popular Solutions for Breville ESP8XL Espresso
Questions and Unsolved Problems for Breville ESP8XL Espresso
Do you recommend Breville ESP8XL Espresso Machine?
Answer
Answer
Filters don't fit into filter holder. Can't put filter holder into place onto machine
Answer
My frother no longer functions. What should I do?
Answer
Why am I having difficulty getting a rich cup of coffee when I pack down the coffee in the filter
Answer
When I turn the dial to espresso it makes the sound that the steamer makes and no water comes out.
Answer
the little part were the cofee comes out from is clogged and the water and coffe comes out of the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Breville ESP8XL Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
