Home | Bosch | 24 in. SHU43 Built-in Dishwasher | Dish washer, Water lea...
Bosch 24 in. SHU43 Built-in Dishwasher
Problem for Bosch 24 in. SHU43 Built-in Dishwasher
Dish washer, Water leaks out of right front corner during first
By donichy on Oct 30, 2009
Water leaks out of right front corner during first 20 minutes and at end rinse.
Solution #1
posted on Nov 06, 2009
Somewhat Helpful)
bubbas_house
Rank: Guru
Rating: 93%, 18 votes
it sounds like your machine is over filling. the gasket is not supposed to be under water. check the overflow float inside. it looks like a little hat or cone. it should move freely up and down. if it is stuck down, your machine will fill up too far and then leak. good luck
Was this helpful?
Yes
No
Solution #2
posted on Nov 07, 2009
Not Rated)
Macmarkus
Rank: Guru
Rating: 92%, 66 votes
Donichy, Hi, A common occurance with the bosch d/w aside from mis-diagnosis being #1, is the lower spray arm can split, crack or seperate causing water to spray directly at the door corners instead of upwards, hence manifesting as a leak. It will be easy to confirm or dismiss as well. Remove the lower rack and pull the spray arm straight up out of the support tower and then inspect it very thoroughly. If this should prove to be the fault, replace it with # 167301. This part should be available at most local parts depot's or on-line vendor's. Double check with you "complete" model & serial number located on the r/h side edge of the inner door. Hope that helps, but let me know either way. Good luck. macmarkus :)
Comments:
Nov 09, 2009
- Hi donichy, it`s macmarkus again.
I also wanted to add some info regarding an issue some of the older bosch dishwasher`s had. If you can remove the toe panel or kick plate as some refer to it, (the black panel at the bottom held in place with 2 scews) take a look at the water valve/inlet. does the solenoid part of the valve (where the 2 wires are connected) sit vertical (up & down) or horizontal (side ways).
The reason I bring this up is if the valve is a old style,(vertical) it must be changed for the new style (horizontal) before it fails completely, and when it does it usually fails in the open position allowing water to flow even without power to the unit...which can be disasterous obviously, especially if you are not present when it does. (it may already be failing leading to overfilling). It should be replaced as a precautionary measure even if it is not what`s causing the problem presently. For your info the new part number is 425458. All this info is relative though, dishwasher`s manufactured since around 2004-05 should not be affected. A serial number will confirm or dismiss whether your`s is included or not as will the visual inspection.
Let me know.
macmarkus :)
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SHU43 Built-in
Questions and Unsolved Problems for Bosch 24 in. SHU43 Built-in
Do you recommend Bosch 24 in. SHU43 Built-in Dishwasher?
Answer
Answer
We recently bought an Integra Bosch dishwasher. It cleans well. However during the drain cycle there... (More)
Answer
I swicth the dishwasher on it lights up, starts the cycle and then stops after a few seconds, have... (More)
Answer
Replace front panel with stainless steel . It is an older model, SHU4300
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU43 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
