Question about Toshiba Tecra M1 PC Laptops
Kernel data inpage error
i have toshiba tecra tm1 laptop and i am trying to install a new copy of os winxp but during the installation a masege comes KERNEL DATA INPAGE ERROR and instalation stops. please help i need my laptop back Thanks
  • 1 more comment
  • Darko Jovanovski Jan 02, 2008
    i have formated my disk. Everytime i tryed to install the os i always format the disk
  • Darko Jovanovski Jan 03, 2008
    i checked my ram with memtest86 and there were no problems but when i tryed to check HD a problem became
    so do i need new HD ?? Thanks
    President:
  • 4,402 Answers
It is best practice with a used computer to completely format and
clean-install Windows. In your case, this is what you definitely need to
do after performing some hardware diagnostics. Here are links that will
show you how to do a clean install and what you will need on hand:
http://michaelstevenstech.com/cleanxpinstall.html
http://www.elephantboycomputers.com/...alling_Windows
Posted on Jan 02, 2008
  • Cary Farah
    Cary Farah Jan 03, 2008
    next thing to do is take out everything extra and everything possible that you can, and when you go to install select customize and select min (least amount of stuff to install) configuration
  • Cary Farah
    well thats a good question, you said you formated it and it formated ok, i would do a fdisk, do you have a old boot floppy with fdisk and format on it? if not google floppy boot disk utils, then fdisk the drive and see if you get any errors
Computer clicks then shows the kernel data inpage error screen
I'm sorry to say but that sounds like a hard disk failure. Classic symptoms.
Run a diagnostics test using Seatools:
SeaTools Seagate
Mar 21, 2014 | ASUS Silver 15.6" Vivobook V550CA-DB71T...
Windows installation setup says not find any hdd disk drives installed and says cannot continue
You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key. Check if BIOS still recognizes a hard drive. If not, you need to physically reconnect drive and try again.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
I search for a driver for my laptop TOSHIBA T9000 MODEL N° PT900E-06QW3-FR
Drivers are dependent on the version of Windows installed. You can download from Toshiba support page but they may only work on XP or older. If you have installed a new OS, try installing XP drivers or search Windows update.
Click here to go to Toshiba driver download page. Drivers are for Tecra 9000.
Dec 05, 2010 | Toshiba Tecra 9000 Notebook
I have a toshiba satellite a205-4707 when i got it it would freeze at startup i had a ancient copy of xp pro sp1 i could only install with power cord unplugged.even after install if i plugged in power cord...
http://www.4shared.com/file/oE15gXll/killdisk_and_boot-cd-iso.html
get this from my shared drive(read instructions in there)
and wipe your disk clean (Warning...this process will make you lose all data on disk so be careful, if posible backup all critical data that you need)
once done install WinXP SP3(get a Windows XP cd from a friend or download a pirated copy from net) look for "WinXP SP3 piratebay" in google
when installing WinXP make more than 2 partitions (C, D, E)
Install WinXP in C
once done, let Windows boot and show Desktop
install WinVista or Win7 in D
use E for saving your critical data
Nov 29, 2010 | Toshiba Satellite A205-S4617 Notebook
Drive Smart Read Error / Kernel Data Inpage Error/1000-0143
have you restarted the PC? If you have and it works, then this error is NOT too much to worry about... As long as the drive is Booting for now you can copy off your files etc to say a USB drive... You do not need to copy the programs etc, usually you simply copy over your "My Documents" or "Users" directories. As all files saved are generally "Under" there if you have any, anywhere else of course you need to get them as well. Now the drive may NOT be totally "Ruined" it may simply require a Re-Format, and then replace the Operating System. After which you can restore your settings. Below is a Microsoft link that tells you how.www.microsoft.com › ... › Computer Setup and Maintenance -
Either with the "Old" drive or a "New" drive. set BIOS to boot from CD/DVD and put the Windows Install DVD in the drive, boot of this and follow instructions, when you come to the place to partition & Format, do this and do a full NTFS format... after which your system will be installed and you can load your drivers and programs again Also before doing all this go to the manufacturers web site and download ALL drivers for your model PC & Operating System. You need to do this so you can install the drivers for all your Video, Sound, WiFi network etc. after you install your operating System
Mar 08, 2010 | Dell Inspiron 2200 Notebook
I have a toshiba tecra m3.i tried to install windows xp media center edition????with no joy! it keeps saying install disk 2 when i install disk 2 nothing happens , i have windows on the laptop but nothing...
First you have to know if that Windows XP Media Center is compatible with your laptop, it should be properly installed to avoid errors.
Second if you don't have drivers, you have to access the internet so you don't have any choice but to use another computer to download all the drivers for your laptop
Here's the site for your tecra laptop
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=882872&rpn=PTM30U&modelFilter=M3&selCategory=3&selFamily=1073768664
Jan 11, 2010 | Computers & Internet
I am not able delete data on pendrive my laptop winxp os
Check that the correct driver is installed for your pendrive and check that your usb port is not damaged.
Dec 12, 2008 | Computers & Internet
Driver touchpad
hi D.
your laptop has same components as the Toshiba
Tecra M8-ST3094 !
- try townload the driver fitting to your Windows version at :
(copy and paste the link!)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=835450&rpn=PTM20U&modelFilter=&selCategory=3&selFamily=1073768664
download it directly onto the laptop or any other internet-pc available, transfer the data using usb-flash drive (usb-stick, usb-mp3-player) or burn it onto a CD
- copy the downloaded driver software to your harddisk, the desktop for example, then double-click onto the .exe file(it is a selfinstaller for winxp and win2000) let it work it's magic, reboot the laptop and things should be fine now!
good luck
Oct 22, 2008 | Toshiba Satellite U305-S7448 Notebook
Kernel stack inpage error
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Feb 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Tecra
it can not run it in safe mode and when i run it last good configuration it starts checking the disk and some record segments are unreadable 9284 9285 9286 9287 after it finish checking it restarts and setup is being restarted90579ca.jpg but why i cant instal a new copy of xp
Jan 01, 2008 | Toshiba Tecra M1 PC Laptops
Toshiba Tecra M1 PC Laptops Logo
239 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
