Home | RCA | D52W20 52 in. Rear Projection HDTV-Ready Tel... | I Have a D52W20 that wil...
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Problem for RCA D52W20 52 in. Rear Projection HDTV-Ready Television
I Have a D52W20 that will not turn on. The cycle
By steve_moraca on Oct 30, 2009
I Have a D52W20 that will not turn on. The cycle on time went from 5 seconds to 45 seconds with a slight arcing noise coming from the high voltage flyback section of the PCB. Now it cycles on then off. Is this typically a component fix or does the whole PCB get replaced?
Solution #1
posted on Nov 04, 2009
Not Rated)
gullipudstvs
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 186 votes
It seems that you are having an issue with your ballast. This is one one the common symptoms they have when they're becoming faulty.
Was this helpful?
Yes
No
Popular Solutions for RCA D52W20 52 in. Rear
Questions and Unsolved Problems for RCA D52W20 52 in. Rear
Do you recommend RCA D52W20 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
How long to an unplugged complete idle discharge for an RCA D52W20 rear projection? many thanks
Answer
tv wont turn on the green light comes on for a second or two then goes off then comes back on and... (More)
Answer
i have arca hdtv rear perjection #d52w20 the power light keeps going out
Answer
i have an rsa 52'' hdtv. when i try to turn on ,the power light go's off
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA D52W20 52 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 699
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
