Question about Fisher and Paykel DEGX1 Electric Dryer
Lint assembly-Fisher and Paykel DEGX1
How do I remove the lint assembly? Also, I found the red reset button, but how do I reset the circuit board?
Thank you
  • 2 more comments
  • Flabergasted May 23, 2008
    Where can I find a parts manual for this model dryer?
    Thanks!
  • amember Jan 17, 2009
    Did it work? I changed mine out after finding tears in the internal filter, but still having to pull lint bucket and remove to expose sensors and still have alot of lint built up back there. What did I do wrong?
  • adori May 11, 2010
    Where are the two screw caps? I can't get the front panel off.
  • Anonymous Mar 26, 2014
    LINT FILTER WAS FULL TO MAX
Pretty easy on the lint assy;
Remove the lint cup;
Find screw (5) in a recess at the bottom of the lint cup area;
This will allow removal of the perforated lint surround, and the 'lint scraper'; Also will expose the moisture sensor (3) hanging off wires at the bottom of the assy;
At the bottom of the surround there is another recessed phillips screw; remove this, then twist the surround (14) counter-clockwise about 1/2" and remove to expose the filter (13).
<img src="http://img50.imageshack.us/img50/9130/outlectductsh4.jpg" alt="FP Dryer Lint parts"/><br/>
Not sure on the reset- I do know the top swivels up after removing the two screw caps and screws at the front of the unit on either side. This exposes the underside of the control panel; there are screws at the back of the control panel also.
Posted on Apr 24, 2008
6ya staff
SOURCE:
We bought this dryer the year Fisher and Paykel introduced it in America.(probably 2005??) It has had one problem before and that was fixed by a technician. Now the dryer at the end of the last cycle had...
Hi Lynda,
I am inclined to think that you have a faulty control board. Moisture from the dryer does tend to corrode the PCB (circuit board) and you end up having irregular faults.
Get your husband to unplug the dryer and then remove the screws from under the display/touch panel. Gently remove the display panel exposing the control board behind it. Note the wiring position which is connected to the board.
Detach the board from the plastic panel and physically inspect the boared for signs of corrosion or dry solder joins. Note there are two boards cased together (Display and Control PCBs). The part is sold as one unit.
Ash
Sep 13, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
DEGX1 that was not heating correctly. Cleaned behind lint trap and pushed the reset button (did not feel tripped though). My question concerns the "Sensor Conductivity" or two chrome bars at bottom of...
Make sure that onw wire is coneected to the top bar and one wire connected to the bottom bar. DO NOT connect both wires to one bar, it make short out the control circuit. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum make further help you through your problem.
Sep 19, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My Fisher Paykel dryer DEGX2 WAS TAKING LONGER AND LONGER TO DRY CLOTHES AND THEN JUST STOP DRYING-DOESN'T GET WARM. THE HEATING ELEMENT WAS REPLACED ABOUT 7 MONTHS AGO. IS THERE A RESET BUTTON IN THE...
Hi.
There is no reset circuit.
Parts that must be tested are high limit thermostat and timer board.
The timer board is replaced if it is visibly faulty, or if there is no problem elsewhere.
The high limit located near to the element is tested reading impedance with a multimeter set at Rx1. If there is no continuity , the thermostat must be replaced.
Before testing parts check the lint filter, and ensure that air ducts are clean.
Regards.
Nov 13, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel degx1 lint trap won t release
Probably the holder/bearing for is out of place... it is really hard to get it out if this is the case but you can try putting a putty knife in between the top of the lint trap and the bearing and pressing down on the knife. If you get it out the lint scraper will have to be reset, F/P may be able to walk you through this.
Apr 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Burning smell after hitting the reset button
the lint may have moved into the motor/ or other areas, clean the unit again and have another inspection, checking for burn't wire etc.
Jan 25, 2009 | Fisher and Paykel DEGX1 Electric Dryer
It wont heat at all. lint trap empty, good air flow
needs a heater rework kit probably. contact fisher paykel and they will pay for the repair.
Nov 02, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
859 people viewed this question
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
jimorris77
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
