Question about Sony PlayStation 2 (PS2) Console
Disc tray rattles
My disc-tray rattles when i insert a cd into my ps2
  • 3 Answers
The screws on top of the disk tray may be loose u can take it in or fix it yourself if u dont mind takin your ps2 apart or have already just make sure screws on top of disk tray are tightend down all the way its an easy fix but be doing this it voids warranty and i i think that if seal on back is broken u cant take it in to have it fixed.
Posted on Jan 02, 2008
Disc tray on my ps2 broke
its difficult.. but not impossible...
there r 2 push-buttons when you disamble the ps2 and u need to press them continuously in order to run your cd!
here's the solution go to youtube and search play ps2 cd's without the upper tray cover....
Jan 09, 2013 | Sony PlayStation 2 (PS2) Console
Playstation makes a clicking sound when disc has
This means the cd has not been inserted properly.When inserting cd,make sure you hear the 'click' sound as you press it on the central part.
May 02, 2010 | Sony PlayStation 2 (PS2) Console
When I go to play a game on my ps2 and put the game in the ps2 eye prevents the disk from spinning I have the newer ps2 that is slim the eye that reads the disk keeps sliding up and the disk does not get...
Does this happen to all of your Discs? If you know someone who also has a PS2, try to run your discs first on that PS2...If they worked, then probably either the lens of your PS2 needs to be replaced, or it only needs cleaning. Or it is also possible that your disc isn't inserted on the disc tray properly...and by "inserted properly " on the tray I mean is to make sure that the 3 pins on the spinner of your PS2 are sticking out of the hole on the DVD and thus gripping the disc...
Aug 01, 2008 | Video Game Consoles & Games
Disc Tray
The rubber band inside your PS2 might be broken, the rubber band supports the disc tray and it ejects and inserts the tray.
Sometimes if play too much long, some of the PS2 parts will be damaged by excessive heat, so my advice is that your minimum gameplay time must be 3-4 hours only.
Please den't even try forcing the tray to open, it will be more damaged.
Try resting your PS2 for about 1-2 days, after that try to open the tray, if the problem still persist bring to a PS2 fixer near you.
Jul 29, 2008 | Sony PlayStation 2 (PS2) Console
Jammed PS2 DISC TRAY
If your ps2 is in the upright position this could be the problem as the disc will not sit propeely and rattle around and cause scratches, the best way to have it is in the downright position as the disc tray will be flat and wont slouch down, try turning it on and pressing the close switch.
Jul 03, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 stuck on memory card screen
If its not an original disc, meaning if it was copied or burnt, then this will happen. However if it is in fact an original PS2 disc, then I'd suggest taking it out, cleaning and trying again.
Mar 21, 2008 | Sony PlayStation 2 (PS2) Console
My Sony PlaySatation2 console wont read any games on PS2 discs.
Check this web site out, this will help you, this problem happens alot so dont worry you should be able to do it yourself. http://arstechnica.com/articles/paedia/hardware/ps2.ars/1
Mar 12, 2008 | Sony PlayStation 2 (PS2) Console
Disc wont work
Hi AdalVI,
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Sony PS2
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 07, 2007 | Sony PlayStation 2 (PS2) Console
Disk reading error
Hi Tyrell,
What kind of disc is it? The PS2 can sometimes have a dirty lens and not read discs. It does not matter if the Disc is new and unscratched.
  4. REmove the Warranty sticker to the right edge of the power socket.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  10. REmove the little white disc from the Cd tray lid.
  13. Put it back together, and your in business.
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
150 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
