Home | Kenmore | 50522 / 50524 Side by Side Refrigerator | Which gas was used in ...
Kenmore 50522 / 50524 Side by Side Refrigerator
Problem for Kenmore 50522 / 50524 Side by Side Refrigerator
Which gas was used in refrigerator
By nagar_harish on Oct 30, 2009
which gas was used in refrigerator
Solution #1
posted on Oct 30, 2009
Not Rated)
jackfrost555
Rank: Guru  Refrigerators  Expert
Rating: 93%, 66 votes
Prior to 1999, all refrigerators used R12,commonly called "Freon".
After that date due to mandates by the Montreal Protocol, the refrigerators were forced to switch to R134A, the same refrigerant used in automobiles since 1994.
R134A is less efficient, and far more troublesome than Freon 12, but the manufacturers had no choice.
Somewhere on your machine there is a placard that lists they type of refrigerant. Inside the freezer compartment or fresh food compartment, along the front rail of the machine behind the grille, or on the rear of the machine, many times even on the compressor itself.
It will usually give the amount of charge in ounces along with the type of refrigerant.
If it says dichlorodifloromethane then it is the old method of describing R12.
Units in leisure vehicles running on gas instead of electricity, use ammonia.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 50522 / 50524 Side by
Questions and Unsolved Problems for Kenmore 50522 / 50524 Side by
Do you recommend Kenmore 50522 / 50524 Side by Side Refrigerator?
Answer
Answer
My side by side refridgerator/freezer stopped working. Neither side will cool.
Answer
My Kenmore Ice maker produces Ice just fine, but I end up getting a big clump of stuck together ice... (More)
Answer
Leaking water from the bottom. The water pan was full. I turned off the water and the leaking... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 50522 / 50524 Side by...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 893
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
