Microsoft Xbox 360 Console Logo
Posted on Jan 02, 2008
Disc Drive MY Xbox 360 won't play any disc. When I put a game or DVD in, it simply spins the disc out of the tray. It makes a werid grinding noise and then says "open tray." The disc just won't stay put.
A
Anonymous
1helpful
2answers
Grinding noises and wont accept disc
your dvd rom drive is gone you can get this replaced by someone that knows how to do it but if its still under warranty send it to Microsoft
Open tray error
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
Disc Grinding, Not Motor or Magnet Thing
I think the only option for you is buy a replacement drive off ebay (you want the same model doesnt matter about the FW version) swap the PCB of the drives over so the new one has your old PCB. The same thing happened to me but when I lubed the spindle the grinding noise went away for a week at a time, so I got fed up of constantly lubing it and bought a new one off ebay and swapped the PCB worked brilliant ever since. Hope this helps.
Paul
Inserted disc press play grinding sound and disc left scrapped
If your xbox box it's new I would take it back and get another one, becase you do probable have problems with your dvd drive and it will keep scratching the games. the laser on the drive doesn't work as hard when playing a music cd than when it plays a game or a dvd.
If you don't want to take it back, then play a couple dvds and if it reads then fine then you could try again. it shiudn't take more than ten second to read a game so if its taking longer just get it out.
Loud grinding, spinning noise with game in console.
Even if it is still playing dvds it might be the dvd-rom drive, usally it spins a game faster than a dvd. Or it could be the harddrive if it was trying to save something. try to download a demo or something to check the hard drive.
2answers
Xbox 360 Disc drive
no that's not good the motor is working over time you need it looked at quick or the moter will give up and then it will be a bigger job more money try thhttp://www.gamevania.com/XBOX_360/repair.phpis site first.
8helpful
7answers
Xbox 360 disc drive
To april23
what has most likely happened is that the magnet which holds disks in place has dis-lodged and is now stuck to the roof of the dvd drive. Unfortunately the only way to resolve this would be to open up the xbox 360 and open up the dvd drive to fix.
So if you're not confident at this or in doubt in any way I'd contact Microsoft first if it's still under warranty, if not then it's a case of opening up the drive yourself I'm afraid.
Note. Does the drive attempt to spin up when you put a disk in?
Or does it just make small noises then nothing except "open tray" on screen?
360 grinding noise and unplayable disc
Crack open the DVD case and see whats going on and try fixing it yourself. OR Buy a new drive off of eBay and transfer the firmware key over from the old drive too the new one.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
