Question about Microsoft Xbox 360 Console
Xbox 360 sound problem
If i use the component cable supplied i get sound but not the great picture i get using my tv's full 1080 output, if i connect with a hdmi cable i get a great sharp picture but no sound, i have tried a different hdmi cable and still no sound, HELP i'm getting so frustrated with it..
  • Nick1024 Apr 18, 2009
    We put in The HDMI and it took a moment but it started to work. i played For 2 days and then went to my fathers for a week. I just came back and everything was fine except no sound. we unplugged and plugged back in but it still didnt work. WE Cant put in the HDMI and The regular Componets tht come with the Xbox in at the same time cause it doesnt Fit. I Need Help!!!!!!!!!!
I've got the same problem. Tried different HDMI port and also new cable. Still no sound. Thought it might be the game so I tried playing a demo from the harddrive and still no sound. Any help would be appreciated.
Posted on Oct 02, 2008
I'm having the same problem. It would work fine b4, not it doesn't. Any ideas?
Posted on Jan 08, 2008
    Problem Solver:
  • 5 Answers
HDMI cable does carry sound. You will need to set the xbox 360 to output sound on the general setting tab. DVI connection does not carry sound to clarify.
Posted on Jan 02, 2008
  • 85 Answers
HDMI carrys no sound you still need to have the audio cables from the component plugged into the tv. If this doesnt do the trick you should call MS or check your TV's settings maybe there is a special function when using that resolution. Hope this helps.
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
and for the video reset about halfway down the page:
Mar 30, 2011 | Video Game Consoles & Games
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
I get sound but no picture on my xbox 360
Wiggle the end of the cord a little bit. same thing happened to me
Jun 27, 2009 | Microsoft Xbox 360 Console
Xbox 360-no audio output
You may need to go into your TV settings and turn on HDMI Audio. If this is not enabled (Typically on HDMI 1) The TV will not ask the 360 for Audio and as such won't pull it.
Jun 20, 2009 | Microsoft Xbox 360 Console
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Sound no picture
your cables are probaly broken go to for trouble shoting tips.
Jun 19, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
214 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
