TEAC DV-W24E Not working
Computer lists Code 41 can't find hardware
The CD//DVD seems to be running okay. Light comes on and I can hear the cd spin
  • 2 more comments
  • baysurfer Mar 30, 2008
    I enter any dvd/cd, and the drive can't read it. i go to microsoft device manager, and it says code 41 - the drivers were installed but can't find the hardware even though the hardware is there.
    The device is TEAC DW-224E.
  • Anonymous Dec 24, 2008
    1. computer not recognizing dvd burner
  • Anonymous Feb 18, 2009
    the same
  • jeffry28 Apr 15, 2009
    code 41, how do I get rid of this?
  • 45 Answers
Does the drive appear in the BIOS and the device manager?
Posted on Jan 02, 2008
  • Denise Dooley Jan 02, 2008
    You can also try the fixes below..
    http://www.dougknox.com/xp/scripts_desc/...
    Use this one with caution..
    -Click Start button
    -Click Run
    -Type "Regedit" without the quotes
    -Locate the "HKEY_LOCAL_MACHINE" node
    -Followed by the "SYSTEM" node
    -Followed by the "CurrentControlSet" node
    -Followed by the "Control" node
    -Followed by the "Class" node
    -Locate & Click on "{4D36E965-E325-11CE-BFC1-08002BE10318}"
    On the right panel look for the 'UpperFilters' and 'LowerFilters' keys.. and delete them.
    Note: sometimes both are not there.. it can be one or the other. In either case delete any instances of it.
    Windows upon reboot, will recreate those files fresh.
    REBOOT YOUR MACHINE
  • dgreenblaze
    dgreenblaze Feb 05, 2013
    GENIUS!!! Thanks for the fix Denise.
Techychick's solution worked for me! Thanks!
Posted on Mar 30, 2008
TEAC CD/DVD problems
Hmm, sounds different to the usual problems I've come across but try this:
Paste the following into a new text document and "Save As..." type "All Files (*.*)" and call it "DVD Fix.bat"
@ECHO OFF
REG DELETE "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}" /v "UpperFilters /f > NUL
ECHO Press any key to restart the computer.
PAUSE > NUL
Shutdown.exe -r -t 0 -f -c "UpperFilters reg key removed to fix CD/DVD-ROM" -d p:2:3
Run the file and restart your computer when prompted.
If you're trying to write to a blank disc, make sure in the drive's properties that you have recording/burning enabled. If you do, try re-installing your CD/DVD burning suite. If you didn't have one, try a system restore.
If this doesn't work or you've disable system restore, you can go into hardware manager and roll-back the driver. If you don't have a roll-back available. uninstall the driver and restart your computer. A default Windows driver should then install.
Check the drive is physically performing - does it load/eject the disc? Does it spin-up? Are you able to read any discs?
I you have any further problems, it would help if we had the model name of your laptop.
Jan 08, 2014 | Teac (DW-224E) DVD Drive
what sort of problems are you having with your teac dvd burner?
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Sep 26, 2011 | Teac (DV-W58GA-PUK) Burner
Does anyone know how to de-code or hack a TEAC DV-H500 cd/dvd player. After owning for several years i still can't play or watch many disc's. Many Thanks
This works with some dvd players, don't know if it'll work with yours... With the remote, open the tray... punch in 9,9,9,9...and then enter, and then '0' and hit enter again. This breaks the region code or allows playing of any disk.
Jan 06, 2011 | Teac DV-H500 DVD Player
I have an external teac dv-28e-n usb DVD writer device which does not recognise and burn DVD rewritablce discs.
I think that Teac DV-28e Is a CD/DVD-ROM only, and will not burn discs. Teac DW-28e is a CD RW/ DVD ROM unit, and will thus play and burn CDs, but will only play DVDs. Check your model numbers to confirm, and then consider exchanging units if you need to burn CDs.
Dec 20, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
My teac dvd/cd player wont play some cds
Probably a codec problem on the notebook. rather than a drive problem. Try a 3rd party media player such as Real Player or Quicktime
Feb 15, 2009 | Teac CD-Rewritable W28E CD-RW Burner
Solve this problem
You need to download the driver for this device from the manufacturers website. Reinstall the device using the new driver. This should fix the problem. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | Teac CD-Rewritable W28E CD-RW Burner
TEAC DV W28ECT ATA DEVICE CODE 10
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Aug 24, 2008 | Teac CD-Rewritable W28E CD-RW Burner
CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Nov 09, 2007 | Computers & Internet
Cdrom
Try this but be careful to find the exact key as not to do damage!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Nov 05, 2007 | Teac (DW-224E) DVD Drive
Computers & Internet Logo
1,099 people viewed this question
David Payne
David Payne
