Toshiba 32A33 32" TV
Problem for Toshiba 32A33 32" TV
My picture turns into a white line
By kekkc on Oct 30, 2009
My picture turns into a white line and comes back if you hit the front bottom of console?
Best Solution
posted on Oct 30, 2009
Very Helpful)
raklein62
Rank: Wiz  Televisions & Videos  Expert
Rating: 85%, 123 votes
I think you flyback transformer is going out. Eventually it won't come back when you hit it.
Comments:
Oct 30, 2009
- Have a Service Tech change it for you. You can change it but it will shock the day lights out of you if you don't follow procedures like unplug TV and place a resistor across certain pins. Are you good with electronics and electricity? Just do some home work and get instructions before you do the job. I like the service tech idea because, they always will do additional checking on the set for you for free. It shouldn't be that expensive of a job. A tech could do it in less than a half hour. It is also possible a connection problem or a EEprom connection Vpos problem so, I'd just have the service tech do it. Besides they also have the service manual.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you but what is the solution? " - kekkc
Solution #2
posted on Nov 14, 2009
Not Rated)
Bat1956
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 309 votes
If you are indicating that the picture collapses to a horizontal line (side to side) then this has absolutely nothing to do with a flyback. Since it does respond to impact, there must be a bad solder connection on the main board. If horizontal, it will be in the area of the vertical driver IC. It will get worse until it fails altogether, but it is easier to find at that point.
Comments:
Nov 14, 2009
- The solution of course is to repair the bad solder joint. There are some parts in the area of the vertical IC that run rather warm, as evidenced by circuit board discoloration. Check the soldering at those parts first. If nothing stands out, just resolder those parts to elliminate them as being a problem.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 32A33 32" TV
Questions and Unsolved Problems for Toshiba 32A33 32" TV
Do you recommend Toshiba 32A33 32" TV?
Answer
Answer
i need the code for my toshiba tv to use the satellite remote control instead of the remote that... (More)
Answer
my tv has red stand by light on and green flashin light..no picture
Answer
my Toshiba 32 inch tv, the menu options keep flashing across the bottom of the sreen and wont stop.... (More)
Answer
My remote doesn't work but the batteries are fine. Also the volume and channel button on the tv... (More)
Answer
Our tv hums everytume you turn it on...no picture or sound...is it fried???
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 32A33 32" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
