posted by Fran73 on Jan 02, 2008
I have a problem with my Ony DSC-W55 camera. It says access and then restart the camera but then nothing happen and turn off again...
What is going on??Please, help
Thanks
Francesca
32 Other Users Have The Same Problem
Posted by jmadris on Nov 29, 2008
it says access when I turn on the camera
Posted by Guest on Nov 29, 2008
Hi, when you say 'the left side' is that looking at the lense or the screen?
Thanks
Posted by markd33 on Oct 20, 2008
Exact same problem.Was using the camera and all was fine.Turned it off for 5 minutes,went to use it again and all the pictures were blurry.Turned it off again then back on and got that "access" message.The lens would then go in and out 3 times.After the lens stopped acting like it was possessed I would then get the message to turn the camera back off and then on again.Of course by doing this the exact same process would happen all over again.
Called customer service and they had me try a few things with the camera,non of which worked.
I've had this camera for around 14 months and this is now the second time it's gone completely out. Luckily(I guess) for me I bought the extended warranty.Pain in the *** to say the least having to deal with that.Won't be buying another sony camera anytime soon.Very disappointed in my current choice.
UPDATE:Tried smacking the camera on the left side(like someone on here suggested)and the camera is now working fine again.How long is anyones guess but hopefully it will last long enough for me to save up and buy a cannon :-)
Posted by tadpolefarm on Oct 01, 2008
I have the same problem. No fix yet.
Tim, Kamloops
Posted by rosie_0108 on Sep 09, 2008
My camera, also a sony, does this exactly. I have seen two solutions : gently rotate lens OR the one down the bottom, kick it on the left, and neither have worked at all. Annoying as I'm overseas and kinda need it
Best Solution
posted on Oct 13, 2008
Rank:
Master
Rating: 90%, 9 votes
Was this solution helpful? Show your Appreciation by rating it:
Best Solution
posted on Feb 02, 2008
Rank:
Apprentice
Rating: 99%, 18 votes
Just kick it few times on the left side of the camera and the problem will be gone. Same thing happened to me and it worked.
Best Solution
posted on May 25, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
I kicked it few times on the left side of the camera and the problem was solved. That was the solution.
Best Solution
posted on Sep 15, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
I have this camera too and if you smack it on the left side of the camera the problem is fixed.
You may need to do it a couple times but eventually it goes away
Best Solution
posted on Jan 30, 2008
Rank:
Master
Rating: 86%, 78 votes
1.turn the unit on and switch to play mode(picture preview mode)
2.press the menu button
3. select setup
4. inside setup and search for setup 1 (option with a toolbox icon with a number at the bottom.)
5. inside setup1, pls select initialize and reply with OK to evety prompt(using the center button)
6.if succesfull(you'll get clock settings)
7.set the date and time then try the camera again.
8. if it prompts you to turn the power off and on again.... turn off the unit,remove the battery for 1 min and press and hold the power button at the sae time.
if this does not work.... call sony cust service 1800-222-7669
Solution #6
posted on May 22, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
mientras esta accediendo dale un golpecito y arrancara.-
when said the acces word on the screen. made a little hit and gonna start
o solucion 2 really works
Solution #7
posted on May 19, 2008
Rank:
Apprentice
Rating: 40%, 1 votes
say access, turn the power off and on again........
i do same as massage appear
but still got the same problem
Solution #8
posted on Oct 19, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
how can i remove "access" error form DSC S55.
Solution #9
posted on Oct 15, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
Same problem here.Camera is less than 1.5 years old and have already had to send it back twice.Lucky for me(I guess)that I bought the "extended warranty"
Was using the camera and all was fine.Literally two minutes later the few pictures it would take came out blurry.I turned the camera off,turned it back on and the word 'access" appeared on the screen.The lens would go in and out three times too.After the lens stopped doing whatever it was doing I would get the message to turn it off then on again.Doing that did nothing.
Very disappointed in the quality of this camera.The one I have is the cybershot dsc-w55
Guess its time to give canon cameras a try.
Solution #10
posted on Oct 10, 2008
Rank:
Master
Rating: 64%, 14 votes
Solution #11
posted on Oct 09, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
I did solution #2, no help, but followed with solution #1 with adaptation - I'm not kicking my camera! (the poor thing gets used by 450 students a year already -- it gets kicked enough) I turned it over, tapped gently on the face side nearest the wrist strap and it started up after two tries.
Solution #12
Rank:
Apprentice
Rating: 0%, 0 votes
bang it few times close to the lens area. Very gently! Voila there you are!!! :)
it's as simple as that!
Solution #13
posted on Sep 18, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
the same problem it saying turn off and to restart
Solution #14
posted on Jul 23, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
I tried but nothing..and they're selling this for 300 hundred dollars..
Righ now I am gonna write a warning in Amazon.
32 Other Users Have The Same Problem - Continued
Comment by RockvilleNSW, posted on Aug 25, 2008
The same problem in a camera that is only 6 months old. I took it back to the retailer who sent it off for a warranty repair but was told that the warranty was voided as the camera had been allowed to get wet - which was not the case and there are no signs of water penetration even around the battery terminals which is where I'd expect to see evidence. I was quoted $ 400 for a repair and when I declined the retailer insisted that I should pay $ 60 to return the broken camera to me - all up leaves a bad feeling and no camera.
Comment by rjleurck, posted on Jun 28, 2008
Exact same problem. If you hold the camera up to your ear you can hear a clicking sound as the actuators for the lens attempt to do whatever mechanical process they need to allow the camera to display a "live" picture. Playback of images on memory stick is fine. Tried reset procedure with no luck. Camera a christmas gift has been hardly used . Have dsc-s700 which has been working fine. No wonder Best Buy had this one on sale ! (I hope not !)
Comment by Cassie21, posted on Jun 24, 2008
I switch my DSC-W55 camera on and the lens moves in and out and beeps, at the same time it says Access on the screen. It then changes to say Turn the power off and on again.
I tried the solution of initializing the settings more than once but the second i choose ok after updating the time/date the Turn the power off and on again returns.
Comment by mkaay, posted on Jun 20, 2008
I too have the same problem. The camera is basically brand new. I sent it in to get repaired in Laredo, TX Sony Repair Center. They claimed it had been misused and it has severe dents, scratches on it. They tried to sell me a "newer and better" camera right away. Said our warranty is no good under such circumstances. I asked to have it sent back. Honestly, I still can't find a scratch on it and it I know has not been dropped, etc. I contacted Sony Customer Support twice. They will only go off of what Laredo Repair Center says, even though everyone else is claiming to have the same issue and it has to be a problem with the camera. Sony is no longer getting our service.
Comment by Jeaux, posted on May 27, 2008
Forgot to put in my text the sony customer service number is 1800-222-7669. Cheers, Joe
I have the same problems as described by many in this website. I called Sony customer service and I worked with a technician that had me do a routine similar to the one shared by the master tech on this site. It still did the same thing after the routine. The technician said it is a problem with the lens accomodation and he issued me a work order to send the camera in to be fixed. If camera still under warranty, call customer service and you pay to send the camera in, they fix it and send it back to you free. They will create an event number and issue you a work order to send it in. They want a copy of the purchase receipt but, if you don't have receipt, they can track the purchase date based on the camera serial number and issue you a letter via email to send in with the camera that verifies camera is still under warranty. Take home message here is if you read the troubleshooting issues on this website, it behooves you to get you camera in as quickly as possible. They guarantee a 10 day (or less) turn around time on your camera once received. After you send your camera in, you can go to
www.sony.com/repair and put in either you work number or event number and it will give you the status of your camera repair at that monent. Hope this helps some. Cheers, Joe
Comment by Guest, posted on May 26, 2008
My Sony DSC-W55 says Access and then Restart. how can i fix it.
Comment by Guest, posted on May 25, 2008
Comment by lagabe, posted on May 24, 2008
I had the same problem and solution 1 actually worked. Better than the $110.00 that Sony wanted to charge me. Does anyone know what is stuck inside that causes the problem? Is there a small hard drive inside this thing?
Comment by akshaykumar, posted on May 19, 2008
i only follow the instruction trun off and on again
Comment by cichan, posted on May 18, 2008
Exactly the same thing and I tryed the both solucion and didnt work :o(
Comment by otilio, posted on May 13, 2008
Buenas tardes tengo un problemita, mi nieto dejo caer la camara y no se retrae el lente, y al tratar de encenderla me dice que vuelva a encender la camara, tendran el manual de desarme para checar la funcion del lente.
I have a problemita Good afternoon, my grandson dropped the camera and not retracts the lens, to try to turn it on and tells me to re-ignite the room, will have the manual disarmament to check the function of the lens.
Comment by Guest, posted on May 12, 2008
I have the same problem. Seems to be a mechanical issue with lens opening properly, possibly dirt in mechanism or messed up gears. Does anyone have a service manual for the DSC W55 that shows how to open and clean the lens mechanism?
Comment by Guest, posted on May 11, 2008
hi i have the same problem so some one help me
Comment by jhoselin, posted on May 07, 2008
my cyber-shot DSC-W55 says ACCESS when turned on and to shut off and on again but when done nothing happened and now magically it dosn't say access or any of that same stuff, now the images ara blurry on screen
Comment by Guest, posted on May 05, 2008
says access then lens winds in and out again and again then it says press on and off button
Comment by 123formula, posted on Apr 27, 2008
Comment by angie12345, posted on Apr 19, 2008
im having thee same problem too!
when i turn on the camera,it says Access
thenn it starts beeping sayin Turn Power off and On again.
ive tryed so many times and it doesnt work.
i tryed that solution below and it also doesnt work.
pleassse help : (
angie
Comment by Blondie73, posted on Apr 14, 2008
I'm having the same problem... I turn it on and the screen said access, then the lense starts going crazy!!! It's driving me nuts. This is my second Sony camera in two years. The 1st one had a similar problem but I attributed it to the fact that my daughter dropped my camera. the new one had just came out so just made her buy me a new one. That is the pink one I have now. It is not resetting no matter how many times I try to reset it with the directions provided. I guess I'll call customer service and see what I can figure out... Wish me luck!
Amber
Comment by Starkladybug, posted on Apr 13, 2008
I have the same problem with my DSC W55. access & then "Turn off power & on again" but no solution. At first it would just happen every now & then (in other words I turned it off & then on & it worked) but now it will not take pictures. I followed the directions below for reseting the clock but still no luck. Has anyone contacted Sony & if what did they say?
Comment by Guest, posted on Feb 28, 2008
i m facing the similar problem wth ma sony w55....i have corrected it twice wth a technician but the problem reoccurs again...the same old message turn off and then turn on the power...
Comment by Guest, posted on Feb 03, 2008
I can view only my pictures. The camera will not turn on for taking photos and the lens does not open out. The screen reads access then turn the power off and on again. This does not fix the problem. I followed the steps suggested on this site (twice) but this did not fix the problem. Any more suggestions. Jenny
Comment by Guest, posted on Jan 23, 2008
I have had my Sony DSC-W55 for two months and I absolutely love it. Recently it began showing this Access then Restart message then goes off. I have tried restarting the camera, I have tried changing the battery but to no avail. The lens also seem to be stuck for some reason. It comes on, I am able to view previous photo but it does not take new shots. Please help!!
Comment by marie13080, posted on Jan 12, 2008
When I turn the Camera on. It comes on, but the lens keeps going in and
out, and then it eventually goes in all the way, and the screen says
turn power on and off again. i have turned it on and off and it does
the same thing.
I haven't dropped my camera and its not even a month old.
so i don't know what could have happened to it.
If you could help me, please contact me at my email at:
hollister_chick_13080@hotmail.com
my name is Marie
Thanks
:D
Comment by Guest, posted on Jan 07, 2008
I have, the same problem but no solution, anyone please help????
Comment by rori, posted on Jan 04, 2008
the same thing happened to me.
i turn on my camera and the lens thing goes in and out and says to restart it,
so i do, and it does the ssame thing.
