Question about GE 46GW947 46" Rear Projection Television
JVC AV61 pro Rear Projection TV not powering up. Seems to be stuck on standby?
  • boturki Mar 08, 2008
    yes i have the same too
    not powering up at all
  • seddor bernard May 13, 2008
    My AV-61 PRO doesn't power; I just need service manual. When I power it the red tube makes some "clickings" and no one accepts to try to resolve without a technical manual. (I am a french speaking person; so excuse my english) . thanks
    sedber.
What's your problem?Pioneer PRO-530HD 53 in. Rear Projection Television flashing red standby light
This and a few other models like it have one real common issue:
they develop from age and heat bad solder connections all over the power board (rather large board).
My experience with them is the fix usually is remove rear cover and follow power cord to power board (a lot of plugs to mark) and remove that board----then solder every single connection on the board which by the way has some special fuses on it.
Jun 14, 2012 | Pioneer PRO-530HD 53" Rear Projection...
Have a Pioneer pro elite 730hdi. When you try to turn it on (main power, not standby), the tv cycles from the red (standby) light with the normal click to the green light, then one second later, it cycles...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Aug 09, 2011 | Pioneer PRO-730HDi 64 in. Rear Projection...
TV won't turn on, it has a blinking light on the power button
It seems that the power is reaching the power switch. The power switch seems to be at fault. If you can remove the rear cover to replace the power switch. Or replace the whole module as that would be easier.
Jan 19, 2011 | JVC HD-56G786 56" Rear Projection HDTV
My power light and lamp/standby light blinks.... no picture or sound... Grrrrr help pls
The projection lamp on this tv like 1 1/2 or 2 years has not been replaced in this tv and it turn on and watches tv 4 or 5 hours every day?Yes,than the projection lamp life is over.Require replacing a projection lamp.
Oct 18, 2010 | JVC HD-52G786 52" Rear Projection HDTV
The TV went on standby last night, the TV was then switched off at the mains last night and then this morning it seems to be stuck in the standby mode - can you help?
Replace both of your STK ICs they are big black ICs will have part number on them STK392-020 or 040s also replace 2 resistors 2.7ohms in front of ICs Call Mats Electronics for parts 1-800-628-1118
Dec 29, 2009 | Samsung HCM4215W 42" Rear Projection...
TV keeps changing channels by itself
Either the channel up or down buttons on the tv are most likely stuck.
Aug 07, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Convergence is off
Starts up with black raster, then shuts down with LED blinking 4 times
This is the micro telling you that the auto grey-scaling procedure has failed. Change resistors R909, R913 & R922 (180k, 1%) on crt base PCB. You will probably find that all these have gone high
Standby only
Check R101 (4.7ohm), TR102 (C6180) and C126 (47uF, 16V)
Tv turns on automatically. Power supply works well, +5V present but seems that CPU (7700) does not (no standby mode), no remote or control on the front of the set
After replacing CPU (TMP47C434) and crystal 1770 (4.0MHz) both control worked intermittently. Replacing transistor 7674 (BC548) solved the problem
Will not work, standby (red) LED flashing
C604 in the 12V line is bad
Int going into standby
Replace C454 a 22nF smd, located near the Frame o/p ic.
Nov 24, 2007 | JVC AV-56WP30 56" Rear Projection...
Re: standby mode???
No really the standby mode dosent mean the sets fried or unrepairable. It just means that the sets in a shutdown mode till a power supply problem is corrected. They have shut down protection when the power supply dosent regulate the b+ and if it didnt shut down it would give off tons of X type radiation. thats just a safty on the set. seek a pro to assist you in repairing the set. Good Luck
May 16, 2006 | Hitachi 50EX01B 50" Rear Projection...
GE 46GW947 46" Rear Projection Television Logo
366 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
