Nope, neither of these answers are working. I've tried three different Sandisk, standards and Ultras...these all work in my Canon SD600 and my computers card reader but not in my Jazz.
Hello Friend,
first suggestion is to try formatting the card from the camera menu. Go to your camera menu and find the reformat card selection.
If this doesn't fix the issue, you will need to try another memory card since this one can be defective.
My last point here is to highly use a top brand memory card like panasonic or scandisk with the option HDSC.
Best Regards,
I assume it is reffering to your memory card. If it is, then your memory card is write protected. Just remove it and search for a tiny button by the side that you can switch forward or backward. Toggle it to the other side and insert the card back. It should work then.
my jazz189 goes black when I plug either of the included camera A/V cables to my HD TV. What am I...
(More)
my jazz189 goes black when I plug either of the included camera A/V cables to my HD TV. What am I missing?
jazz elite HDV 178. when i plug in the charger, the light blinks 3-4 times and then goes solid. what...
(More)
jazz elite HDV 178. when i plug in the charger, the light blinks 3-4 times and then goes solid. what is the problem?
my camera will not turn back on nor will it charge, when i put it on the charger the light will come...
(More)
my camera will not turn back on nor will it charge, when i put it on the charger the light will come on red for about 2 minutes then it goes away
