Toshiba e310 Pocket PC
Problem for Toshiba e310 Pocket PC
I have had this charging overnight but it won't
By jjuettner on Oct 30, 2009
I have had this charging overnight but it won't charge. What should I do?
Comments:
Nov 09, 2009
- You Rock!!!
Best Solution
posted on Oct 30, 2009
Very Helpful)
cq92
Rank: Wiz
Rating: 84%, 85 votes
It's probably the battery - some laptops and pocket pc's indicate the battery has charge or may be low - when plugged in say they are charging but the charge indicator does not move at all - usually then the battery is defective. Post Solution
Comments:
Nov 08, 2009
- The back part of the case should have 4 screws to remove and the battery is held in place with a glue strip and it will have a cable to unplug. The new battery should be charges 3 hours before use.
Here are pictures and instructions :
http://www.pdainternalbattery.com/e310install.htm
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you. Is it possible to replace the battery? How? Or is it junk now? " - jjuettner
Solution #2
Very Helpful)
hichama9
Rank: Guru
Rating: 89%, 35 votes
Hello Friend,
It depends on what you mean by charging overnight.
1. When you connect the charger, it shows on the phone that it's charging but after a while if you unplug the charger, it's still not charged: if it's the case, that means the battery is dead and needs to be replaced.
2. When you connect the charger, it doesn't show the phone charging: in this case it can be the charger brocken or the phone charge connector is faulty. you can verify that by moving the charger connector a little bit and see if it will start charging, if not you can try with another charger. if it doesn't charge even with another charger, at this time i will say for sure that the phone charge connector is faulty and needs a repair.
Best Regards,
Was this helpful?
Yes
No
Asker's Testimonial
" Thanks. I just need a new battery. Good news to me. " - jjuettner
Popular Solutions for Toshiba e310 Pocket PC
Questions and Unsolved Problems for Toshiba e310 Pocket PC
Do you recommend Toshiba e310 Pocket PC?
Answer
Answer
How do I change the battery in the Toshiba Pocket PC e310? I can't find it in the manual.
Answer
I cannot make first connection. I have installed the latest Active Sync but cannot complete... (More)
Answer
How do you connect a toshiba e310 to the internet? I heard you need an SD wireless card but i do not... (More)
Answer
i try to charge it through the usb port but it wont charge is there a different way to do it?
Answer
when i charge the Toshiba Pocket pc e310, it appears to be charging, but when i unplug it, it does... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
