its a tuner that is failing on your set it can be replaced but it might be to costly for a set of its age and im sure the picture tube is starting to show the tales of age also not a repair id suggest
My Zenith (Model B25A1OZ; Manufacture Year 2000)alternates from a steady picture to like it has lost...
(More)
My Zenith (Model B25A1OZ; Manufacture Year 2000)alternates from a steady picture to like it has lost its Horozontal Hold, there is a double picture ( one on top of another) how do I fix this? There are no Horozontal/vertical Hold Knobs
My grandma has one of these Tv's. Recently when you selected closed captions it does not work and...
(More)
My grandma has one of these Tv's. Recently when you selected closed captions it does not work and she needs it. Any ideas>?
at initial turn on zenith b25a10z tries to sync with signal, turn off after failure to sync. will...
(More)
at initial turn on zenith b25a10z tries to sync with signal, turn off after failure to sync. will continue to turn off if not sync. 10mins later after repeated turn on the tv stays on and the pic is sync.
