Question about Dell Inspiron 1526 Laptop
How to remove Insperon 1725 keyboard - Dell Inspiron 1526 Laptop
    Problem Solver:
  • 14 Answers
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Posted on Oct 30, 2009
  • Deep2009 Oct 30, 2009
    • Keyboard
    • Dell™ Inspiron™ 1525/1526 Service Manual
    • CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in the Product Information Guide.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer.
    • Removing the Keyboard
    • Follow the procedures in Before You Begin.
    • Remove the center control cover (see Removing the Center Control Cover).
    • Remove the two screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    • To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer.
    • Slide the keyboard cable out of the keyboard connector.
    • 1
      screws (2)
      keyboard
      keyboard tabs (5)
      keyboard cable
      5
    • Replacing the Keyboard
    • Slide the keyboard cable into the keyboard connector.
    • Rotate the keyboard connector latch to secure the cable.
    • Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    • Press on the right edge near the top to snap the keyboard into place.
    • Replace the two screws on the top of the keyboard.
Hp625 keyboard figures 5 and 6 not working
Posted on Oct 21, 2012
SOURCE:
I forgot the unlock code on my Insperon 13z 5323
If you are referring to a password? Is it the BIOS or Login password?
Apr 13, 2013 | Dell Inspiron Computers & Internet
I have lost my Manual for the AT&T 1725 answering Machine. Can you mail me a new manual? Send to Burnley Miles, 5325 Calvin Court, Colfax, NC. 27235
Retrevo has the manual for the AT&T 1725 here: http://www.retrevo.com/support/AT%26T-1725-manual/id/473bh046/t/2/ . You will need to enter a code to download the PDF. Adobe Reader or a similar program is required to read the file. You can print it out yourself or take it to a print shop.
I hope this helps.
Oct 26, 2011 | AT&T 1725 Answering Machine
How can I retrieve messages accidentally deleted?
Look for the manual of your AT&T 1725 digital answering machine
Jun 26, 2010 | AT&T 1725 Answering Machine
What store carried bissell 1725 in the past 5 years
No store has carried model 1725-1 in the last 5 years. The model was replaced 8 years ago by 1425-1.
May 31, 2010 | Bissell 1725-1 Little Green ProHeat...
Dell insperon has sticky keys can i fix it
With sticky keys, that means that something spilled into the keyboard or the keyboard has not been cleaned in a very long time. Below are instructions on removing and replacing the keyboard. Once you have removed the keyboard, clean each of the keys and replace in the appropriate places. Follow instructions below for removal and replacement:
There is nothing geeky in knowing how to remove a laptop keyboard. You can do the same by following some easy to do steps. Please remember that laptops from different manufacturers are very different from each other, and the difference between two models from the same manufacturer might be too much to say the least. The process showcased below is for a Dell laptop. Before undertaking this project all by yourself, it is recommended that you go through the manual provided by the manufacturer or do so once or twice in presense of an authorized technical person.
1 Remove the keyboard bezel. Take a screw driver and put it at the slot of the bezel and using it as a lever pull off the bezel. Once the bezel is displaced the screws that hold the keyboard and the system-board together are visible.
2 Loosen the screws that attach the keyboard and the system-board with a screwdriver of appropriate size. Pull-off the screws once they are sufficiently loosened.
3 Hold the keyboard in your left hand and try to move it at an angle of 45 degree. You will notice that the only other attachment the keyboard has is a cable with a pin at it's end that fits into a socket placed on the system board.
4 Holding the keyboard in your left hand at a comfortable distance, pull the cable pin out of the socket in vertical direction using your right hand. Once the pin is out you will find the keyboard removed.
I hope this was helpful.
Jan 04, 2010 | Computers & Internet
AC ADAPTOR (power) for AT&T 1725 answering machine
Radio Shack It Just Needs The Same OutOut Voltage It Should Say On The Bottom Or On A Tag Somewhere Output 9v Or Whatever
Jan 05, 2009 | AT&T 1725 Answering Machine
Singer 1725
The hook drive gear is seized and requires lubricant ,this is the gear right behind your bobbin case I believe you can access it from the rear ,I hope this helps
Nov 29, 2008 | Singer 1725
Dell Inspiron 1526 Laptop Logo
1,076 people viewed this question
Clive
Clive
Alun Cox
