Maytag washer makes a squeaky noise when washing
My maytag washer sav2655aww makes an ugly squeaky noise when washer is washing or rinsing and stops squeaking when on spin cycle. to me it sounds like it needs oil or tighting of the belts? pls help!! I have a Magic Chief top load Washer that makes a squeak or rubbing sound in the agitation cycle . I have removed the agitator and inter tub and all looks good. Squirted WD40 under the outer tub and it still squeaks under a heavy load. It makes less noise with a lite load. Could the springs that hold the tub be weak ? This washer also gets out of balance very easy. The washer is level. The washer is only about 1 year old however inside the machine looks very cheaply built.
  • Anonymous Dec 14, 2008
    I have the same problem on an older model. Please let me know if you find a solution
  • Anonymous Jan 04, 2009
    kemore model 1102970090 portable washers squeaking while washing. any help would be great.
  • 1211 Answers
SOURCE: maytag washing machine #mav6260aw
If you are a good DYI'er you can find the parts here http://www.repairclinic.com/0003.asp you'll need a couple of hours set aside and maybe a few beers for after. If you are not going to fix it yourself the labor costs and parts would come
to just about the price of a new one. Hope this helps.
Posted on Nov 11, 2007
  • 63 Answers
SOURCE: Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Posted on Nov 14, 2008
hektor1961
  • 70 Answers
SOURCE: clacking sound on agitate cycle only, no noise on spin
Jake,
This specific model uses a brake package that is giving you both noises.
Replacing the brake package will take care of it.
That washer is a jewel - they don't make them like that anymore.
Posted on Aug 18, 2009
Testimonial: "sounds like the right answer, i will attempt to fix thanx"
  • 121 Answers
SOURCE: GE Washer Model WJRR4170E4WW squeaks while agitating
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
For more on do-it-yourself appliance repair help visit http://www.appliance-repair-it.com/index.html
Posted on Sep 17, 2009
Testimonial: "shawnryan111, thank you for a great suggestion. That did the trick and the machine runs much more quietly. Thank you for the assistance. Regards, Les"
  • 29 Answers
SOURCE: I have a brand new
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
Posted on Feb 20, 2011
I have a brand new Maytag Bravos MCT top loaded washer. It makes a squeaky noise when agitator is cleaning. The squeak is getting louder and I've probably only used the washer a dozen times. We checked...
Feb 20, 2011 | Maytag Dependable Clean Top MAV5920EWW Top...
Trying to put belt back on magtag sav2655aww. do
Maybe this breakdown250 will help, not sure, hope so.
Nov 11, 2009 | Maytag SAV5710 Top Load Washer
In spin cycle machine makes squeaky noise.
Your bearings could be going out, causing excess stress on the belt. Take the back off of the washer and check the belt tension. If there IS something stuck back there, you'll be able to see it.
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer SAV2655AWW - pulley wheel replacement
WHICH PULLEY FELL OFF YOU HAVE 3 OF THEM ONE IS A "IDLER PULLEY FOR DRIVE BELT" ANOTHER IS "PLASTIC HELIX, TRANSMISSION DRIVE PULLEY" AND LASTLY IS "PULLEY FOR TRANSMISSION DRIVE" GO TO www.repairclinic.com ENTER MODEL NUMBER AND SCROLL ALL THE WAY DOWN TO THE RED 100 CLICK IT AND LOOK FOR PARTS 550204, 889619, AND 889618. YOU MAY HAVE TO WORK ON THIS FROM THE BOTTOM TO GET TO THE PULLEY. IF YOU HAVE A MECHANICALLY INCLINED FRIEND, IMPLORE HIM OR HER TO HELP YOU UNLESS YOU CAN GET THE TUB OUT AND WORK YOUR WAY DOWN
Apr 18, 2009 | Maytag SAV2655A Top Load Washer
Timer won't stop
If the timer is still running thru stop points and continues running thru you timer is definitely bad.YOU EASY PURCASE ON AT YOUR LOCAL MAYTAG DEALER OR ONLINE. Glad to be of service.
Jan 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't fill
First take off the fill hoses from the washer, make sure the screens on the washer valve are not clogged. Next heck nd make sure you have water coming from the hoses. Finally if still no water. you may ned a new fill valve. Hope this helps , Dave www.washermd.com
Dec 22, 2008 | Maytag HAV3460AWW Top Load Washer
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
it really depends on where you buy them gan go here and get part numbers http://www3.sears.com/
Jan 24, 2008 | Washing Machines
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
1,270 people viewed this question
Top Washing Machines Experts
