Question about Maytag MDB7100AWB Dishwasher
Maytag mdb7130aws dish washer
I had a service guy tell me i had a bad control panel. i got a new panel and i stalled it myself but it didnt do anything. i found the pcb test and did that 212345674 and know the only thing that works is heavy wash and heated dry. is there some kind of reset or did i do something wrong?
  • greg m Jan 07, 2008
    the problem was dish washer was not filling with water. i was able to get new control panel to work i had a bad connection but my first problem is still there not filling with water. all other functions seem to work ok. but when washer calls for water nothing. i have to add water to do my dishes.
  • Anonymous Aug 07, 2008
    My Maytag dishwasher also will not fill the water although everything else seems to be working. Checked the inlet valve for 110 volts during the fill cycle and got nothing. When I opened the door and checked the circuit board, I noiced that the cover has black soot and that a component on the board is completely burnt out. Can't tell if it was a resistor, capacitor or diode, but whatever it was it was small. Knowing that the new board would cost at least $150, what do you think I should do? I'm tempted to find out what that component was and replace it myself, but is concern that it might burn out again. Any suggestion?
Yes i have power to water valve.
Posted on Jan 08, 2008
  • 90 Answers
What was the main problem
Posted on Jan 05, 2008
  • Douglas Woods Jan 07, 2008
    have you checked to see if you are getting power to water valve at start of cycle
Washer does not respond to control
Hello Walt;
My name is Peter. I am a retired field service appliance technician.
Maytag makes a good unit. Please give me more information. Is it a clothes washer or a dish washer?
Please provide the model number so I can see what you have.
These numbers are on the machines, usually after you open the door you will see a name plate.
1.) Do you have power? Does the control panel light up?
2.) There are several reasons your unit may not respond to the control.
a.) A faulty door lock switch will lock out your control.
b.) Both clothes and dish washers have thermal fuses. These too will lock out your control.
Once again send me your model number and more detail & I will help you.
Peter Goodwin
Glen Burnie, MD
443-306-1362
Jan 13, 2015 | Maytag Washing Machines
MDB 8750 Dish Washer Doesn't start the Wash Cycle.
Yes this can be a touch pad failure that may need to be replace again , because with this type of device usually the touch pad is easy to get bad...
Good luck........
Aug 19, 2008 | Maytag Dishwashers
Where is the fuse for the samsung dmr77 dishwasher
Hello Margaret;
Unfortunately, Samsung does not design their appliances to be maintenance friendly. You have a inline fuse that is in the wiring harness, inside on the on the bottom right hand side.
Substitution: Part Number 3601-001197 Cost: $4.00
You have to remove the right lower side panel to access the harness. The side panel is held on with one screw. Then pull toward you to remove.
There are several reasons your dish washer will not run.
You could have a bad door contact switch:
Remember to turn the power off first.
You could have a bad door contact switch, or one of many other sensor.
Tell me what the problem is. Is your control panel lit up?
Dec 24, 2014 | Samsung Dishwashers
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
Kitchenaid Dish Waher KUDI01ILBS1 won't run from control panel
Sounds like the control is bad. Turn off the power, remove the two screws at the bottom that secure the kick panel. Remove the kick panel and look under the machine for a folder up tech sheet. This will tell you how to get the machine into diagnostic mode. Follow the instructions exactly and it will help confirm whether it is the control.
Jan 15, 2010 | KitchenAid Washing Machines
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer will not Wash/Spin
take the back of the top console off and there is a service manual there that will help you a lot more than i can type if the guy didnt take it with him anyway, doesnt sound like a door lock problem tho because it will give an error for the door and yes it is a solinoid, the older models had a wax motor
Jul 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag dishwasher cannot choose cycle on light panel
hello hmm ok so no lights it sounds like your control panel after unplugging your dish washer check the panel for loose wires the panel is the part behind were your buttons are located will have to remove your back cover to access this if that's all good then try your power cord again make sure its not got any loose wires were it attaches into the dish washer have a nice day and good luck let me know if you find anything.
Mar 19, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag MAH2400A Front Load
If it's still there, pop out the front bottom panel. There is a Technical Information packet stuffed behind it.
3E says:
"Drive System is not working correctly. Bad windings, speed sensor, wiring connections, or Control Board."
Jan 18, 2008 | Maytag MAH2400A Front Load Washer
Maytag MDB7100AWB Dishwasher Logo
205 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
