4-Pin AC Adapter Works with Acomdata External Hard Drive Enclosure HD Power Supply Cord: Amazon.ca: Electronics.
Rating: 4 · ‎1 review
Missing: hdo40u2e54 ‎' Must include: hdo40u2e54
Find many great new & used options and get the best deals for 4-Pin AC Adapter For Acomdata External Hard Disk Drive HDD HD Acom Data Charger at the ...
You broke it. Does the Acomdata warranty cover self-inflicted damage?
Did you buy it with a credit-card that adds "all-perils" insurance?
All you can do is to disassemble the enclosure, remove the disk-drive,
buy a similar, compatible, disk-drive, install it into the enclosure,
and thus "revive" your external storage device.
initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
download and install a file recovery program. An example is GetDataBack (unfortunately not a freewarebut DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freewarebut FREE TRIAL is available).
should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
You need to do a firmware flash. It worked for me. Here's the link to the fix. http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Try a new enclosure, the case is just that. A hard drive cannot actually repaired. You cant open it and fix it. It's either reliable and functioning or not. Purchase a new enclosure and test the old drive. Data recovery should be the last option..most places charge a down payment on a car, and most of the time ( in my 12 years ) its the cheap enclosure.
