Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 hi My dyson dc07 wont power up, any thoughts on what could be causing the fault. ie does it need new motor.
  • 1 more comment
  • Benx100 Mar 20, 2008
    how do you remove the switch to re-attach the cable
  • Anonymous Mar 23, 2008
    I pushed the start button and it started to start but didn't sound right. Then it slowed and quit. I thought I could smell something before I got it unplugged. Now nothing. I've only had it for a couple of years. Is this the motor bad. Is this common for the famous Dyson Animal??
  • jard40 Mar 24, 2009
    How do I remove the switch on a dyson dco7?
  • 833 Answers
First, check your outlet for power...plug something else in. Then, inspect the cord and check the power switch. You can use a multimeter to test across the power plug of the vacuum in the ohms position. Turn the switch off and on. If it does not change readings...the switch or cord is bad. If it does, it might be the motor.
Posted on Jan 02, 2008
My dyson dc07 wont turn on
Hi Mike, it's Jack at Dyson.
If your DC07 shut off while you were using it, and now will not turn on again, it may have overheated. Most Dyson vacuums are equipped with a thermostat which will shut them off for protection if they begin to overheat. This can often be due to a blockage, or because the filter needs a wash.
However, if it's been over 24 hours and the vacuum still won't run, it's likely there's a fault elsewhere. We'd be happy to help you check for this - you'd just need to give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 27, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dc07
hi there.
see if this link helps you out.
How to Repair Dyson Vacuum Cleaners How to Service Dyson How to Fix Dyson
This could be a faulty cable or switch, but could also be a faulty motor.
or this one might help you.
My Dyson Won Turn On Hunker
if you need to read up some more try this link.
Dyson DC07 Bagless Upright Cyclonic Vacuum NO POWER Google Search
Jul 05, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson stopped working
There are three things that "stop" (no noise anymore) a DC07 working. I will list them in order of the most common to least common faults.
1) The motor is burnt out. Caused by over filling and not cleaning the filter regularly. You must replace the post motor filter when getting the motor replaced
2) The power cord has failed. This can usually be seen by visually inspecting the cord for damage.
3) The on/off switch has failed.
All of these faults should be repaired by a licensed sparky for safety reasons.
Keith @ Dyson Repairs North Shore Auckland
Jun 22, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 is making weird noise
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC07 is making a popping noise in use. Unusual noises can be caused by a number of different issues, and in order to determine exactly what's causing this we would need to hear it. I'd encourage you to call our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). One of our experts will be able to listen to the machine over the phone and diagnose the cause of the issue.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Sparking motor on Dyson assume motor brushes at fault?
A replacement motor can be purchased direct from Dyson via our Helpline on 0800 298 0298 at a cost of £36.31.
Alternatively we can arrange a service for £69 which includes parts, labour and VAT. This can also be arranged via our Helpline.
Kind regards
Darran
Dyson Customer Service
Mar 02, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 suddenly lost all power. Bad power
This could be the switch, but could also be the motor.
The motor has a built in over-current protection device which normally automatically resets itself, but if the motor has had it, it then just cuts out again as soon as you switch it on.
Both the switch and motor are available quite cheaply on eBay, but fitting new ones requires good DIY skills (especially the motor), and some unusual tools (Torx drivers).
Have a look at www.dysonmedic.com which has some great info on repairing your machine, but if you dont feel you can repair it yourself, time to call a vacuum repairer or the Dyson helpline.
Feb 15, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replace power cord on Dyson DC07
The following link will take you to an article on how to change the motor on a DC07. Look at photos 4, 5 and 6 which shows how to disconnect the power cord.
http://www.dysonmedic.com/DC07%20Folder/DC07%20Motor%20change.html
Reassemble by reversing dissassembly instructions.
Dec 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hi my dyson dc07 animal has suction but the brush bar wont turn. If I turn it on there is a horrible noise. The belt is still fine
The belt is probably worn or stretched. When this happens the belt won't turn the roller brush when it is against the carpet. Here is a link for the manual and links for the belt you need:
DC07 Manual
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Nov 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Cyclone will not spin
Even thought the belt may look fine the belt still can be worn and therefore no turn the brush or the clutch. The belts you need are these here:
DC07 with clutch belts
DC07 without clutch belts
Nov 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
371 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
