Question about Nike Triax Speed WR0085 wristwatch
Nike Triax Speed 100
Dropped the watch...stopped working. Pressed all four buttons at once, reset to 12:00 on 1/1, but nothing else works (mode, set, light, etc.). Is the watch doomed?
  • Jamag Feb 24, 2008
    Didn't drop it but have the same problem. Face seems to be upside down with none of the buttons working? Also tried the reset to no avail.
  • Anonymous Nov 09, 2008
    just bought similar watch, and having the same problem.
    President:
  • 563 Answers
Hi Symjoc. I can't find a way to comment there, so I will reply here.
Did you try asking the dealer on Ebay if there's warranty, if not, you can always try to sell it back.
Posted on Jan 29, 2010
My watch has done the same thing, did you have any luck!!
Hi, my nike triax cv10 watch is frozen, tried pressing all the buttons at once but no luck please help?
The display of your watch may "freeze" due to static electricity or recent battery replacement.
If this occurs, press and hold all four buttons at the same time.
This will erase the data in the memory and allow you to reset the watch to the factory settings.
Press and hold all four side buttons at the same time to reset the watch to the factory settings.
Hope this helps.
Sep 14, 2013 | Watches
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Nike Triax Fury works after replacing battery, but buttons wont work or change anything!
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Good luck.aa07e646-2c11-45e3-b8fa-b40ec2fd82c2.jpg
Stop screen flashing on nike trax fury
Nike Triax Fury 100 Super
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
Somehow I managed to reset my Nike triax 50 by pressing the watch up against a metal bar when trying to strap myself in on an amusement ride. I've tried setting the time and even switching modes but...
mcdevito75 here, It"s possible that when the watch got pressed up against that bar and your arm you mis--aligned the buttons (inside the watch) used on the watch to reset it. BEST BET, Visit a small watch repair shop in your area and have them take a look at the watch, or, you can use the repair service directory right here ay fixya, bottom of this page, click on repair service directory then watches.
Jun 27, 2010 | Nike Triax 50 WR0083-029
How to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
Mar 09, 2008 | Watches
Nike triax watch
sounds like the contact inside for the ligt button is stuck on. Remove the back again and take a look at the contact under the light button to see if it is stuck, if so, GENTLY pry it out a bit so it's not touching all the time...
GOOD LUCK
Jan 27, 2008 | Nike Triax CV10 Wrist Watch
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Nike Triax Speed WR0085 wristwatch Logo
245 people viewed this question
Top Nike Watches Experts
Ansel Alberto
Ansel Alberto
TIME TRACK SERVICES
TIME TRACK SERVICES
Are you a Nike Watch Expert? Answer questions, earn points and help others
