Question about Canon PowerShot S3 IS Digital Camera
No power I have recharged my batteries but my canon s3 is wont power up.I . recently had the same problem and called canon who told me to remove the memory card and this worked, but not this time. Any suggestions?
  • 7 more comments
  • kathy2020 Jan 06, 2008
    thanls. Got sorted, cleaned the battery contacts with a pencil eraser and then it worked.
  • rogerloew Jan 09, 2008
    Having the same problem. Sometimes the batteries go dead overnight, sometimes in a week (of no use). Happens with both rechargeable and standard batteries. Very frustrating to not know if your camera will work or not.
  • tammieadcox Jan 28, 2008
    Mine will not power up sometimes after charging even my new batteries. When I tap or hit the battery compartment with my hand and then try it turns on sometimes. I tried cleaning my battery post, still no luck. Help please. Tammie
  • joozeejoosch Feb 10, 2008
    the same thing is currently happening to me. i tried new batteries and removing the memory card but somehow it just would not turn on. this never happened to me though.
    is there a reset button on this camera?
  • Anonymous Feb 28, 2008
    Camera was powered on, went to power off and all power went off (lens stayed open). Batteries are ok, contacts are clean. Removed card and re-inserted. Power will not come back on. Canon Power Shot S3 IS.
  • mcguin1977 Apr 04, 2008
    Unfortunately, my camera got a little bit wet in a rain storm, and at first would light up when I tried to switch it on, and try to power up all the way, but now, will not do anything at all. Have tried brand new batteries and all solutions here. Warranty just expired in January. *sigh*.
  • Anonymous Apr 26, 2008
    Mine won't power up either. The mode lever will not stay put on either the shooting or playback position. Is this the same as having trouble "powering up"? Or, could this be a problem with the lever itself? I have cleaned the contacts and made sure the batteries are charged up. Don't know whaat else to do.
  • Holli1121 Apr 26, 2008
    Mine won't power up either. The mode lever won't stay in either position. Could this be a problem with the lever? The batteries are charged up and I have cleaned the contacts.
    thanx
  • drab May 11, 2010
    had the very same problem. Returned it to CANON through the store I purchased it from. CANON said it was a problem with the shutter circuit and the cost to repair was going to be around $200.00!! I was and am not impressed. CANON would not deal with me direct unless I ship the camera direct to them. The retailer told me that I shouldn't pay to fix it and get a new camera. The camera cost me $600.00 and almost to the day the warranty expired, the batteries started draining! I will get a new camera and it won't be a CANON AND I will also return the camera direct to CANON telling them to fix it at no charge or replace. That way, at least, I'll have something I can sell.
The same thing is currently happening to me. i tried new batteries and removing the memory card but somehow it just would not turn on. this never happened to me though.
Posted on Feb 10, 2008
    Problem Solver:
  • 5 Answers
Try another set of well batteries. I had the same problem with well known, brand new batteries and changed over to disposable AA Lithium batteries and never had the problem again. I have also found that the Lithium batteries last much longer than my rechargebles or the "six-times-longer" brand.
Posted on Jan 06, 2008
One of four rechargable AA batteries have burst...
The ideal way to get it out would be to make a small hole on the battery and drain out the powder inside. A small screw driver should help you do this. You can then compress the AA container by pushing the edges towards the center and take it out.
May 15, 2010 | Canon PowerShot S3 IS Digital Camera
Camera shuts off when zoomed
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Dec 13, 2009 | Canon PowerShot S3 IS Digital Camera
Camera wont turn on. Says lens error and restar camera
If the camera has recently been dropped you may have lens damage that will require professional repair. If it has not been dropped, your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may require professional repair.
Oct 19, 2009 | Canon PowerShot S3 IS Digital Camera
S3 is issue
E18 is a lens error that needs to be serviced by Canon technicians. You may qualify to replace your S3 for a flat rate or to repair, but it is nothing that you can fix at home.
As for the batteries, what brand? If they are rechargable, make sure they haven't been drained-try them in another device perhaps. I drained mine by leaving them on the charger too long and I had the same issue. Try another set of batteries and clean the battery contacts inside the camera with a pencil eraser to get rid of any residue or oxidation that may have taken place.
If none of this helps, call Canon for service or other option to upgrade for a deep discounted rate. Sometimes it's cheaper than to fix it if you are out of your one year manufacturer's warranty.
Hope this helps!
May 31, 2008 | Canon PowerShot S3 IS Digital Camera
Canon MV550i Mini DV Digital- red flashing symbol
from canon's support page:
This symbol indicates an empty or missing backup battery. The backup battery allows the camcorder to retain date, time and other settings when the main power source is removed.
The flashing symbol is not recorded by the camcorder so you can continue filming without problems.
To stop the flashing symbol remove the old backup battery and replace it with a new one, or recharge the built-in lithium battery if the camcorder has a built-in rechargeable battery.
Note: when the backup battery runs out during filming please do not remove the power supply (battery pack) before the camcorder is powered from a household power source and power adapter, or the user settings and date/time will be reset.
For more detailed information please consult the instruction manual.
Feb 12, 2008 | Canon MV550i Mini DV Digital Camcorder
Wont stay on
You need to power it with rechargable batteries. with the MAH being no less than 2000. I bought a charger which came with 2batteries for less than a tenner
Dec 23, 2007 | Canon PowerShot S3 IS Digital Camera
Digital cameras
Try the batteries in another device to ensure the batteries are ok.
What type of bayyeroes are ypu using ing?
They should be NiMah rechargables
Nov 21, 2007 | Canon PowerShot S3 IS Digital Camera
Battery drained and now lens wont retract and ive put brand new fully charged rechargeable batteteries i9n and still wont power opn or anything
I have the same problem.I forgot to get the battery from the camera s when we get the battery inside the camera then charged the battery when we put the battery to the camera it didn't work and no power, I've tried fixing the camera what's the problem and I think it was drained.I've also tried to go to the Canon company technician and they told me that there's nothing that they can do cause it was damaged already and they told me to just new one but my camera is just new s please help me what to do or any solution...thanks and here is my email baby_sykrich@yaho.com.
Nov 11, 2007 | Cameras
Canon PowerShot S3 IS Digital Camera Logo
192 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
