Acer Aspire 6920 16-inch Notebook PC
Problem for Acer Aspire 6920 16-inch Notebook PC
Intermittent - Won't shut down / Arcade page comes up on startup
By cpt_commo on Oct 30, 2009
My one-year-old Acer Aspire 6920 has recently begun giving me problems when I try to shut it down. Sometimes it shuts down properly, but other times it says it is hibernating and then reboots. Once I tried five or six times to shut down, but it came back alive like a vampire. I finally had to do a hard shutdown with the power button.
I have checked the shutdown settings and have tried shutting down with every type of shutdown icon I could find, including the Start button and the Ctrl-alt-delete, then Shut down button or dropdown menu . On the Start button menu, what I seem to remember that used to be the Off button (red) is now a Hibernate button (orangish brown).
Also, when I try to start it back up, it often opens with the Acer Arcade, but without the usual minimize/exit buttons in the upper right hand side. I have to go to the center and click on exit several times or hit the escape key.
Best Solution
posted on Oct 30, 2009
Very Helpful)
taiwos_1
Rank: Wiz
Rating: 83%, 35 votes
well i think its a virus, check your antivirus if its still active but nevertheless my friend u will have to restore your system back to factory settings because some patch files are already missing. so back up your important documents and then restore back to factory mode.
good luck
rate this
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
dwane4444
Rank: Guru  Computer Hardware  Expert
Rating: 87%, 76 votes
It seems you have tried all the normal things, in Control Panel, Power Settings there are options to change what action the power buttons do - you could try those.
If this doesn't work you may have some corruption in your system files. This would mean a restore - either from a system restore point before this started to happen, from a backup you made, or from the repair option of your operating system disk.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 6920 16-inch
Questions and Unsolved Problems for Acer Aspire 6920 16-inch
Do you recommend Acer Aspire 6920 16-inch Notebook PC ?
Answer
Answer
How do i reset the touch pad? it is locked at max volume and will not work when touched. None of the... (More)
Answer
My acer 6920 started making a noise when it is not plugged into the wall or not on highest... (More)
Answer
I have a acer 6920 gemstone blue, and i have a hdmi port on the left hand side of the laptop. it has... (More)
Answer
i have a aspire6920 I loaded a utilitie4s disc that made my computer run slower I uninstalled it and... (More)
Answer
I have Acer 6920 and I'm getting a Blank screen on start up? I've tried Fn and F6 buttons
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 6920 16-inch...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
